Author Topic: Ducky Pocket disassembly  (Read 5627 times)
Offline ipreferpie
« on: Wed, 12 April 2017, 06:33:40 »
Has anyone opened up a Ducky Pockey? I'm hoping to disassemble it so that I can install Zealios into them. Anyone with experience?
Re: Ducky Pocket disassembly
« Reply #1 on: Wed, 12 April 2017, 13:30:01 »
i don't see why you couldn't do it
just don't pry too hard or at too tight an angle if it's snap together.
Offline dantan
« Reply #2 on: Wed, 12 April 2017, 16:30:06 »
That is a very interesting board.
« Reply #3 on: Wed, 12 April 2017, 17:03:33 »
If it's anything like an Alpsulator it'll be a massive pain in the ass to take apart. With the Alpsulator you need to pry the case until you're sure it's going to break before it'll come undone, I only know of one other person taking theirs apart and they broke it.
Offline Cocopah
  • Lurker Extraordinaire
« Reply #4 on: Thu, 04 May 2017, 23:36:56 »
I just opened mine. There are 3 tabs on each side of the front cover. No screws other than on the plate to remove the PCB.
« Last Edit: Tue, 09 May 2017, 18:30:36 by Cocopah »
Offline dantan
« Reply #5 on: Fri, 05 May 2017, 07:26:26 »
More photos for keyboard porn please!
Offline Cocopah
« Reply #6 on: Sat, 06 May 2017, 21:17:22 »
Just finished it up. I swapped the brown switches out for 67g Lubed Zealios. I also didn't like all the black so I did a vinyl wrap on the plate. Here is some pics, sorry for the poor quality, my mother in law borrowed my DLSR.
Offline JunkFace
« Reply #7 on: Mon, 22 May 2017, 10:24:47 »
That Hakko iron is waaaaaaaayyyyy too clean :P
They should look like this
Offline codywanks
« Reply #8 on: Tue, 29 August 2017, 04:56:35 »
Nice work there Coco. The RGB diffraction seems lacking with the stock plate, so I'm thinking about making my plate white as well.
