Author Topic: Help Remapping FC980M Pu/Pd to Home/End  (Read 4681 times)
« on: Thu, 13 April 2017, 08:50:49 »
I've been using the FC980M for a few days now and so far my biggest gripe is that I use home/end much more than pageup/pagedown.
For those that don't know pageup/pagedown is the default action and home/end is available as a secondary function accessed by using the FN button.
I tried using keytweak to swap the functions and it worked partially in that the default action is now home/end however I can't seem to make the secondary function pageup/pagedown.
Any ideas on a better solution?
Re: Help Remapping FC980M Pu/Pd to Home/End
« Reply #1 on: Thu, 13 April 2017, 10:52:10 »
Looks like sharpkeys is the answer, it seems to have worked.
Edit: It might be the combo of both programs.
« Last Edit: Fri, 04 May 2018, 07:47:54 by SpAmRaY »
« Reply #2 on: Thu, 03 May 2018, 17:41:29 »
Finally got caps to match my preference.
« Reply #3 on: Fri, 04 May 2018, 06:48:56 »
How u so rich Spam ?
Tp4 only fordz his 2x ergodoci..
« Reply #4 on: Fri, 04 May 2018, 07:41:26 »
Drugz obviously.
« Reply #5 on: Fri, 04 May 2018, 07:46:58 »
Also this remapping solution is being problematic on windows 10.
Offline ag36
« Reply #6 on: Fri, 11 May 2018, 13:38:54 »
How's about trying Hasu's USB to USB converter? It will come with TMK firmware.
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
« Reply #7 on: Fri, 11 May 2018, 13:53:01 »
Nah for 2 keys free software works fine. No need to spend money that way.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #8 on: Fri, 11 May 2018, 14:16:01 »
Hmmm I think default:
FN + right arrow = End
FN + left arrow = Home
FN + up arrow = Page Up
FN + down arrow = Page Down.
I find that a little bit more accessible because all the keys are next to each other, but if you need them at top right for other reasons then I'm not too sure.
« Last Edit: Fri, 11 May 2018, 14:20:34 by Hyde »
