Author Topic: Vinyl Wrap vs Spray Painting tables  (Read 5142 times)
Offline Encabulator
« on: Mon, 24 April 2017, 11:03:51 »
I really want to redo my entire desk to make it match my all black setup, but I don't know what the better option would be. Spray painting is easier and cheaper, but vinyl has more options. What do you think?
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline Encabulator
Re: Vinyl Wrap vs Spray Painting tables
« Reply #2 on: Mon, 24 April 2017, 11:14:02 »
OR.. table cloth.. $20,  call it a day..
As in a mouse pad or something you put on your kitchen table? My desk is an odd shape, nothing will cover it well and it has 2 layers (pieces of wood) I'll need to cover.
Offline nugglets
« Reply #3 on: Mon, 24 April 2017, 11:40:49 »
Pictures of the desk?
You'd probably be best off refinishing and staining it, assuming it's not plywood or something.
Painting wood can be tricky and I personally don't care for the feeling of the surface afterwards, so it would bother me on a desk.
« Reply #4 on: Mon, 24 April 2017, 11:46:08 »
If the surface is bare wood then I would not recommend spray paint but something more made for wood - some kind of woodstain and lacquer or combo thereof. There are a few options.
I think spray paint could work if the surface is already lacquered but I don't think that that or vinyl is particularly durable, especially compared to woodstain.
BTW. "The 8-bit guy" on Youtube has a video of building a desk with floor tiles on the surface.
Offline Encabulator
« Reply #5 on: Mon, 24 April 2017, 15:12:38 »
I'll take some pictures when I get home, I'm not even sure if it's real wood or not to be honest.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #6 on: Mon, 24 April 2017, 21:44:15 »
i've always wanted to "rhino-line" my desk at home with the fine grit surface.
-Dana
Offline Encabulator
« Reply #7 on: Tue, 25 April 2017, 08:29:13 »
The desk is not real wood. I couldn't really do tiling because its curved at the front slightly
Offline nugglets
« Reply #8 on: Tue, 25 April 2017, 14:23:01 »
Then wrap it, or get a new desk =)
« Reply #9 on: Tue, 25 April 2017, 17:36:00 »
I'm tellin ya'll..
Black table cloth..   DONE !!,   play some dota.. hahahahahahaha
Offline Encabulator
« Reply #10 on: Mon, 01 May 2017, 14:59:20 »
I'm tellin ya'll..
That would look like a pretty ghetto fix IMO.
