Author Topic: [help] Build issue. 4 keys not working after soldering switches on.  (Read 6762 times)
Offline jonovann
Hey i just finished soldering my switches onto my new board for the first time and for some reason the I,U, and *= keys are not working but everything else works just fine. Im not sure what to do so any help would be appreciated!
Re: [help] Build issue. 4 keys not working after soldering switches on.
« Reply #1 on: Wed, 26 April 2017, 19:58:00 »
Most likely you have bad solder joints on those switches and they need to be reflowed.
Good photos would help.
Offline jonovann
« Reply #2 on: Wed, 26 April 2017, 20:14:09 »
Hopefully this helps. Best i could get with my phone
Offline hkf
  • your #1 fan
« Reply #3 on: Wed, 26 April 2017, 20:17:21 »
clean your flux residue (clear puddle near solder joints)
there are so many overflowing onto traces that I'm surprised your board even works at all.
Offline jonovann
« Reply #4 on: Wed, 26 April 2017, 20:18:55 »
What do i use to clean the flux off?
« Reply #5 on: Wed, 26 April 2017, 20:30:34 »
flux has nothing to do with ur issue.
does jumping the two contacts with a wire do nothing ?
Offline jonovann
« Reply #6 on: Wed, 26 April 2017, 20:36:35 »
How would i go about that exactly? Sorry this is my first build with no knowledge of soldering or much to go along with the process?
Offline jonovann
« Reply #7 on: Wed, 26 April 2017, 20:41:21 »
Did the photo help at all?
« Reply #8 on: Wed, 26 April 2017, 20:44:45 »
plug in keyboard,   take anything metal.. touch the bottom of the switch which isn't sending a signal together,   the two main big shiny points. check on microsoft word if that send the key signal..
Check all the keys that don't work,  and check the ones next to it.
Offline jonovann
« Reply #9 on: Wed, 26 April 2017, 20:51:15 »
The switches not working still didnt work when trying that but all the ones around them did.
« Reply #10 on: Wed, 26 April 2017, 21:01:14 »
Are the switches all the way down? The picture makes them look like they aren't.
Offline jonovann
« Reply #11 on: Wed, 26 April 2017, 21:05:06 »
Yeah as far as i can tell they are completely flush
« Reply #12 on: Wed, 26 April 2017, 21:11:04 »
Have you tried heating the solder on the switches that aren't working must enough for it to melt then let it resolidify and try them again?
Offline jonovann
« Reply #13 on: Wed, 26 April 2017, 21:15:26 »
Yeah i just tried that and they still arent responding
Offline kmba
  • Formerly tameone
« Reply #14 on: Wed, 26 April 2017, 21:33:05 »
then it's not your switch solder I suspect.  Could be damaged diodes.  Those little surface mount diodes are notorious for coming loose.  Can you show a picture of a specific switch that isn't working from the bottom.
keyboards.
Offline jonovann
« Reply #15 on: Wed, 26 April 2017, 21:55:09 »
Is this any better? Sorry i dont have the best camera
Offline jonovann
« Reply #16 on: Wed, 26 April 2017, 21:56:08 »
U I += and ] are the keys not working and they are both next to each other if that makes any difference
Offline jonovann
« Reply #17 on: Wed, 26 April 2017, 22:46:45 »
This is my first build and i just finished soldering the switches on a little while ago and everything including the led works fine except for 4 switches. Im really new to all this and tried reflowing the points and jumping them but to no luck. It is the U, I, +=, and ] keys that arent working. Im not sure what to do now hopefully someone can help! Thanks
Offline TalkingTree
    • My projects
« Reply #18 on: Thu, 27 April 2017, 03:12:30 »
If you have a multimeter, you can test the diodes.
Offline jonovann
« Reply #19 on: Thu, 27 April 2017, 22:35:01 »
Just tested the diodes they all seem fine and replaced the switches hoping that they might be faulty but still no luck
Offline jonovann
« Reply #20 on: Thu, 27 April 2017, 22:36:58 »
So i found out that i was jumping the switches wrong and they actually do send a signal but after swapping out switches and testing the diodes i still have no luck. Any ideas? Pretty stumped here
Offline TalkingTree
    • My projects
« Reply #21 on: Fri, 28 April 2017, 03:27:22 »
Try bridging the switch pins to see if the keypress registers. Try shorting Y with I.
Offline jonovann
« Reply #22 on: Fri, 28 April 2017, 04:06:22 »
Im not sure exactly how to do that? Also if it makes any difference somehow tonight i got all the keys working completely fine a couple of times but im not sure how i did it and it didnt last.
Offline TalkingTree
    • My projects
« Reply #23 on: Fri, 28 April 2017, 04:21:01 »
With a jumper wire.
Might be insufficient soldering somewhere around the PCB. Take the PCB out of the case and see if it works. If it does, there's likely something causing a short. Also check the solder around the MCU's pins.
Offline jonovann
« Reply #24 on: Fri, 28 April 2017, 05:22:37 »
With a jumper wire.
It doesnt work outside of the case either but if i press down hard enough on some of the switches enough times it will eventually register. Im not quite sure what to look for in a good solder but it looks good as far as i can tell.
