Author Topic: where can you buy a µTron now ?  (Read 7107 times)
Offline Yuuki
« on: Wed, 10 May 2017, 07:54:10 »
Hello
What the "best" way to get a topre µTron nowadays ?
and is it possible to find it below the 500$ mark ?
Thanks
Offline davkol
  •  Post Editing Timeout
Re: where can you buy a µTron now ?
« Reply #1 on: Wed, 10 May 2017, 08:03:21 »
There's one for sale in Deskthority classifieds—for about $500. I've heard the keyboard's being discontinued.
Offline Yuuki
« Reply #2 on: Wed, 10 May 2017, 08:31:02 »
yeah I saw that one. There is no other way ?
Offline davkol
« Reply #3 on: Wed, 10 May 2017, 08:59:36 »
Proxy from Japan, which is gonna be much pricier.
« Reply #4 on: Wed, 10 May 2017, 09:05:51 »
I think this is a good purchase..  but.. I'm not totally sure on it,   because tenting to 55degrees requires ~150mm inside lift..   Not easy to build durable plastic couplings on 3d printer..
I guess it's always possible to build the ramp then use double sided tape .. yea that's probably the way to go.
Offline Sciurid89
« Reply #5 on: Sun, 04 June 2017, 14:30:56 »
I'm about to post one in the classifieds.
