Author Topic: One of the most comfortable wrist rests I have ever used  (Read 7261 times)
Offline flashquark
    • Flashquark.com | Mech Key Depot
« on: Mon, 15 May 2017, 11:57:03 »
So Im a Logitech M570 trackball user, which means that my wrist stays in one position a lot.
I've gone through a lot of different wrist-rests and I've finally found one that feels amazing and isn't just stuffed with spongy styrofoam material.
Its gel-filled so it keeps its form after long-term use, and has a smooth outer soft, flexible outer plastic covering that doesn't feel scratchy on your skin like those cloth covered ones.
https://goo.gl/zbBfsZ
super comfortable, and feels like boobs.
« Last Edit: Mon, 15 May 2017, 12:01:41 by flashquark »
https://flashquark.com | Keyboards, Keycaps, Switches, and other MK accessories.
Re: One of the most comfortable wrist rests I have ever used
« Reply #1 on: Mon, 15 May 2017, 12:04:59 »
all ur coworkers be like,  why does ur desk have a mini-butt on it.   hahaahahahha
Offline flashquark
« Reply #2 on: Mon, 15 May 2017, 15:33:41 »
Lol, I actually do use it at work, but I suppose it does look a bit odd...
« Reply #3 on: Mon, 15 May 2017, 17:57:28 »
Gotta be careful,  or that cute girl @ wurk will think ur pervy and not start the inter-office affair with you.
hahahahahhahhaahahaha
« Reply #4 on: Sun, 16 July 2017, 06:59:48 »
I use this too! It was the first thing that came up using Google. I love it.
