Author Topic: Bluetooth Keyboard?  (Read 5594 times)
Offline Justintoxicated
Bluetooth Keyboard?
« on: Sat, 01 July 2017, 03:11:29 »
I'm interested in purchasing another keyboard.  I have a brown blackhawk I use for gaming and a topre I use at work.  I much prefer the silent modded topre Leopold, although it does  not have NKRO.
But this new board would sit in the living room, for HTPC use, might use it instead of my laptop keyboard from time to time.  I' not 100% sure I really need this thing, but I can see it being handy way to grab and transfer into another room to wok on a server off the network etc.
I was thinking about getting this board with reds:
https://www.amazon.com/DREVO-Wireless-Bluetooth-Mechanical-Keyboard/dp/B01N7HNY1F/ref=sr_1_1?s=electronics&ie=UTF8&qid=1498895917&sr=1-1-spons&keywords=bluetooth%2Bkeyboard%2Bmechanical&th=1
I looked up the GON NS NerD 60, and while it is beautiful $500 is a bit much for what I will be using it for I think.
Alternatively, I think I could build my own, but not sure I want to embark on that adventure wit so many other unfinished projects!
Offline Belfong
Re: Bluetooth Keyboard?
« Reply #1 on: Sat, 01 July 2017, 03:13:49 »
Probably off topic, but I am interested for those who build your own PC, and your mobo has no Bluetooth, what do you do? Buy a USB Bluetooth dongle?
edit: or for those l33t gamer using Bluetooth headset with mic; how did you all do it?
« Last Edit: Sat, 01 July 2017, 03:26:55 by Belfong »
Offline Geass
« Reply #2 on: Sat, 01 July 2017, 17:24:07 »
Yeah, just buy a USB dongle, plug it in and then you can connect any bluetooth deivce to your pc.
Offline need
« Reply #3 on: Sat, 01 July 2017, 18:44:21 »
Have you looked at the Filco minila air?
« Reply #5 on: Sat, 01 July 2017, 19:42:35 »
NEVER...  !!
Never what?
Do they still sell the Filco?
Offline Belfong
« Reply #6 on: Sat, 01 July 2017, 22:11:12 »
NEVER...  !!
Never what?
Never Minila Air. It has non standard keys and you can't change the keys in future.
Offline Belfong
Bluetooth Keyboard?
« Reply #7 on: Sat, 01 July 2017, 22:14:29 »
This looks interesting.
https://www.amazon.com/ASUS-USB-Adapter-Bluetooth-USB-BT400/dp/B00DJ83070
Thank you for your suggestion. I knew about the dongle but I'm not sure how practical or reliable it is in a real-world gaming session. Does the Bluetooth disconnect in the heat of battle?
Offline xuanwumen
  • * Commercial Vendor
    • EZKB
« Reply #8 on: Mon, 03 July 2017, 09:37:17 »
For buletooth keyboard, I know Plum nano 75 with bluetooth and RGB backlightings and 45g switches (not real topre though).
NIZ KEYBOARDS VENDOR
Offline Geass
« Reply #9 on: Mon, 03 July 2017, 10:23:37 »
Well, my keyboard isn't bluetooth, but by today's standards there shouldn't be a big difference between bluetooth and cable, so you won't have to worry.
« Reply #10 on: Mon, 03 July 2017, 12:59:37 »
Do they still sell the filco?
The plum nano 75's lack of dedicated arrow keys is a deal breaker for me (HTPC use).
I know... Logitec but considering: https://www.amazon.com/Logitech-Illuminated-Living-Room-Internet-Connected-Bluetooth/dp/B00ZOPVSKW/ref=sr_1_5?ie=UTF8&qid=1499104701&sr=8-5&keywords=htpc+keyboard
Offline Darksair
    • My Homepage
« Reply #11 on: Mon, 10 July 2017, 19:41:17 »
My PC is like that.  Well technically it comes with a wifi/bluetooth sub-board, but I forgot to install it before I mounted the mobo on the case.  So now if I want to install it, I have to unmount the mobo first (there's a screw at the back of mobo).  I could do that, but I find now that my mobo is stuck on the case because of (I'm guessing) one slightly offset hole on the case.
So I bought a PCI-e wifi card with bluetooth functionality.
A weird thing is, as for a PCI-e cards, I would think that both wifi data and bluetooth data can go through PCI-e. But no, on all such PCI-e wifi/bluetooth card, only wifi data goes through PCI-e; for bluetooth, they all have a separate cord that goes to the onboard USB……
(╯°Д°)╯︵ ┻━┻
« Last Edit: Mon, 10 July 2017, 19:42:55 by Darksair »
Offline need
« Reply #12 on: Mon, 10 July 2017, 20:46:41 »
NEVER...  !!
Never what?
This is so untrue, you can easily grab a brand new set in different colours from aliexpress. If you meant GMK/SA sets specifically... you can also say never to ergodox/planck/most 40%, as they aren't perfectly supported. This will only leave you with Fullsize, TKL and 60% to play with  :rolleyes:
I mean this hobby is very much about playing around with limitations, and the filco minila has the best package in the same price tier without question.
« Last Edit: Mon, 10 July 2017, 20:50:49 by need »
« Reply #13 on: Tue, 11 July 2017, 15:02:22 »
I can't find a Minila Air with bluetooth.  Doe sit really exist?
N/M found one https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2156
The spacebar looks real small and price is steep for ABS keycaps?
If they made a layout with bluetooth like my leopold FC660C that would be perfect.
Maybe I should just get a dongle for my FC660C lol  it's not NKRO, but light use so who cares?
This would be for light use and maybe some retro gaming from the living room coffee table.
« Last Edit: Tue, 11 July 2017, 17:06:18 by Justintoxicated »
Offline flashquark
    • Flashquark.com | Mech Key Depot
« Reply #14 on: Thu, 13 July 2017, 12:38:59 »
You may want to also look into the Anne Pro. Its not necessarily better than the Drevo, but it has an entire subreddit at /r/annepro where the community has solved a lot of its issues as well as documented mods for it.
https://flashquark.com | Keyboards, Keycaps, Switches, and other MK accessories.
« Reply #15 on: Fri, 14 July 2017, 14:13:07 »
Thanks, but it needs to have arrow keys, since they are used all the time for retropie, actually they will likely be the most used keys on the board so I won't want another layer for them.
I'm eying this board: https://www.amazon.com/gp/product/B01LZBVKLX/ref=ox_sc_sfl_title_3?ie=UTF8&psc=1&smid=A33NGRV9BJAC4E
It has pretty much everything I require and I would get to try cherry blacks which should be ok for light gaming I would think.
Offline Marvellion
« Reply #16 on: Fri, 14 July 2017, 15:00:43 »
Varmilo is quite solid too. Although if you're gonna use it with a mac, I would check for compability.
« Reply #17 on: Thu, 20 July 2017, 00:43:09 »
one day one of these companys will hopefully make a decent connector with battery that you can use for all keyboards,I would love my 980c to be bluetooth
Offline amnesia0287
  • Formerly Amnesia
« Reply #18 on: Thu, 20 July 2017, 01:43:29 »
Anne Pro
I got mine for the htpc. Remapped it same as my other 60s. Totally standard layout. Pairing is a bit awkward, but it's been perfectly reliable for me.
