Author Topic: Safest concentration of Isopropyl alcohol to use for keyboard cleaning  (Read 23847 times)
Offline Eugene94
I did some research on keyboard cleaning and came to the conclusion that Isopropyl alcohol to best for doing this. But there are many different concentrations of this stuff. What is the safest percentage of Isopropyl alcohol to use? (I currently have a 50% and 70%)
slightly dampen paper towel with 50% is the safest.
just buy the 99% and add water.
99% itself sometimes can mess with the finish, or whatever other chemicals they've used on the board.
Offline Eugene94
What about the 70%?
What about the 70%?
same thing just add water.. until you hit 50
Offline klennkellon
  • I like bottoming out
Vinegar
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
I use technical grade IPA from the lab (99.7%) and I've never had any problems.
Same here, I use 99% and I've never had any problems
it depends on the finish.
for example, coolermaster had that rubber coating before,  if you use 99% on that too often, it will strip it.
Offline ygor
  • eat a butt, monkey lord
Stripping a finish with 99% is a lesson you (hopefully) only need to learn once.
Offline chyros
  • a.k.a. Thomas
Heh, that might explain it. Don't have a lot of keyboards with rubber finish :p .
Offline Merranza
Re: Safest concentration of Isopropyl alcohol to use for keyboard cleaning
« Reply #10 on: Thu, 13 July 2017, 22:19:44 »
What about the 70%?
Go with the 99%. The 70% and %50 are actually lighter in alcohol because they add other components to the formula so it is less abrasive for the skin (read the ingredients on the bottle).
Now I don't have any proof that the extra component would be harmful to the keyboard but I wouldn't take any chance.
I've always cleaned all my electronics with diluted 99% (including monitor and tv panels) and never had any problem.
Offline ideus
  • Björkö.
« Reply #11 on: Thu, 13 July 2017, 22:22:46 »
I have used 70% AL wipes and they work wonders on my OG Cherry sets.
Offline chyros
  • a.k.a. Thomas
« Reply #12 on: Fri, 14 July 2017, 01:05:55 »
What about the 70%?
That sounds bad, actually. Would you want to smear all that crap on your electronics? Oo
Offline jcoffin1981
« Reply #13 on: Fri, 14 July 2017, 19:38:34 »
90 to 99 percent is good to treat the pcb.  Using on keyboard caps and case it is better to use soap and water, 70 percent isopropyl, or my favorite- windex without ammonia.  This is very mild and works.  If you spilled chilly on it however it's best to use soap and warm water.
Offline Elahya
« Reply #14 on: Mon, 25 January 2021, 15:29:35 »
IPA should work. If I remember well at our office we have always our keyboards cleaner every week. I work as a programmer in a mid-size firm. So the fir hired a professional cleaning company specialized in IT offices . First time hearing about stuff like that. But the most amazing part was when I came in the next day. My keyboard was like new without crumbs, hairs, and coffee. I smelled it just to understand how they did that. I've sensed some citrus aroma. Couldn't figure it out but for sure I have to ask the cleaning guy.
« Last Edit: Fri, 29 January 2021, 07:23:18 by Elahya »
