Author Topic: Post Your Fightsticks!  (Read 31739 times)
« on: Tue, 18 July 2017, 17:46:51 »
This thread has been moved, and as such has been re-branded the
Post Your Fightstick Thread
We encourage you to share photos of your custom or noncustom fightsticks here.   :)
« Last Edit: Tue, 05 December 2017, 02:41:14 by noisyturtle »
Re: Best USB fight stick for under $200?
« Reply #1 on: Tue, 18 July 2017, 18:14:57 »
if it's got sanwa parts,  it's pretty much all the same stuff..  just comes down to looks..
pick one that you like the look of..   if it has sanwa, done,  if it doesn't , buy some sanwa buttons and sanwa stick and solder it in.
All that removable/ moddable is gimmicky,   just like moddable switch plates,  you do it maybe once, and never touch it again.
Offline Cocopah
  • Lurker Extraordinaire
« Reply #2 on: Tue, 18 July 2017, 18:25:23 »
I'd say this is the best. They're very popular and also very moddable. They have 2 versions, sanwa and Korean.  I think it's the only stick that's compatible with both sanwa and Korean parts.  It has a full metal case as well.
http://www.etokki.com/Omni-Sanwa-Edition
« Last Edit: Tue, 18 July 2017, 19:05:45 by Cocopah »
Offline Auk
« Reply #3 on: Tue, 18 July 2017, 18:27:56 »
EDIT: nvm, went dyslexic and misread the thread title  :-[
« Last Edit: Tue, 18 July 2017, 19:03:08 by Auk »
« Reply #4 on: Tue, 18 July 2017, 20:02:03 »
So Sanwa > Hori is the general consensus?
« Reply #5 on: Tue, 18 July 2017, 20:55:29 »
hori makes sticks using sanwa parts.
I don't think hori make any sticks without sanwa anymore,  they used to , i have an hrap original which i had to put in sanwa myself.
Offline Cocopah
« Reply #6 on: Tue, 18 July 2017, 21:26:23 »
For the most part, yes. Hori uses Sanwa buttons, but they moved on to using their own stick. The Hori stick (Hyabusa) has an issue with wobbling though. Sanwa is pretty much the standard. Most tournaments are won with Sanwa parts. Fairly recently though Korean sticks have emerged and started winning. I have always preferred Sanwa parts. HAPP stuff to me feels cheap and wears out over time. It's funny you brought this up, the last week or so I was considering getting a new stick too. I will be going with the Etokki Omni in the Korean version, because I'm curious.
« Reply #7 on: Tue, 18 July 2017, 21:44:29 »
EVOs got me hyped  :eek:
Tekken 7 is out and amazing, DBZ Fighters is upcoming, MVC Infinite is in the wings - It feels like a good time.
« Reply #8 on: Tue, 18 July 2017, 23:23:35 »
man,  there was this super cute female in the audience once..
I can't get into tekken..
For example, you have games like CHESS, many many possible moves..   but it's playable because the rules don't change..
Fighting games change up the rules with every new iteration or patch..    just throwing alot of your practice hours away.
« Reply #9 on: Wed, 19 July 2017, 11:47:51 »
hmmm Pretty sure I'm gonna go w/ a fanta stick as I like the shape way more than ball-top
seems better for 2D fighters
Offline Cocopah
« Reply #10 on: Wed, 19 July 2017, 11:59:09 »
You can get bat tops for other sticks. Just know that the Fanta stick works a little different than the others on the market. The Fanta stick doesnt have a traditional gate like the others. The "gate" is internal. It also doesnt use a spring, it uses a rubber gasket. Its best used without touching the gate. They call it hair trigger, so its meant to play just past deadzone. Personally thats how I play so i'm looking forward to it lol.
« Last Edit: Wed, 19 July 2017, 12:10:47 by Cocopah »
« Reply #11 on: Wed, 19 July 2017, 12:21:21 »
Oh I see, so it operates more like a flight throttle than a fight stick? Maybe it'd be wise to pick one up to just test, $30 is't too bad of an investment.
ty for the info
« Reply #12 on: Wed, 19 July 2017, 12:43:51 »
I love fight sticks yet do not own one. Really wanted to build my own but it ain't cheap. Looking forward to seeing what ya get
« Reply #13 on: Wed, 19 July 2017, 12:44:25 »
Get a B15 SDM.
Offline Cocopah
« Reply #14 on: Wed, 19 July 2017, 12:45:44 »
Get a B15 SDM.
Haha I like the way you think
Offline clacktalk
  • circa 2015
« Reply #15 on: Wed, 19 July 2017, 12:48:54 »
panthera/hrap for sf/anime. etokki fanta **** for tekken
diary of a clacktalk
radio_killah: too much frank
« Reply #16 on: Sun, 23 July 2017, 00:01:47 »
Welp, got mostly everything I wanted ordered. Should take almost a month for everything to arrive - will post more when the time comes.
Went with the Omni Sanwa Edition after doing some research. Probably could've gone w/ a Quanba and saved $50 but whatever, I can mod to Fanta if need be w/ the Omni.
Sanwa wooden bat-top w/ a 2lb spring
8-way gate
and some pretty gold Sanwa buttons w/ silencers (now to wait for Sanwa to make 'em in 24mm as well)
Very excited, my first fightstick!
« Last Edit: Sun, 23 July 2017, 00:04:17 by noisyturtle »
Offline Cocopah
« Reply #17 on: Sun, 23 July 2017, 00:40:52 »
8-way gate
Great choice, and nice first stick man! I blew my new stick budget on a a Ribbit haha. I just got notification that these just came back in stock. They seem to sell out pretty quick so I'll probably pick them up and throw them in my modded Chun-Li stick. Let me know how you like that stick, its supposed to be awesome!
« Reply #18 on: Mon, 24 July 2017, 12:08:31 »
8-way gate
i'm not convinced mx is the right choice for fight stick,  because the stem is not round,  which means applying pressure to different areas of the button top will result in slightly different actuation timing.
« Reply #19 on: Mon, 24 July 2017, 12:12:33 »
8-way gate
I'm intrigued to see how it will feel, but I'll stick to Sanwa for now. Always a safe bet.
Offline Shapey Fiend
« Reply #20 on: Tue, 25 July 2017, 09:20:11 »
I use an old Hori Fight Stick 2 and a Soul Calibur 2 stick. I don't really play fighters it's more retro games. Think I played approx €20 for both of them new.
I used have a Namco stick which I loved weight and feel of but it went rusty sadly. Didn't think my room was that damp.
« Last Edit: Tue, 25 July 2017, 09:22:44 by Shapey Fiend »
« Reply #21 on: Mon, 31 July 2017, 16:27:07 »
It's here!
gonna get to modding immediately
« Reply #22 on: Mon, 31 July 2017, 17:34:08 »
It's here!
This is the easy part..
Now  you need to master all the marvel vs capcom loops.
Offline fleischverpackung
« Reply #23 on: Fri, 18 August 2017, 11:47:41 »
200 wtf.
what about a broken neo geo controller and an arduino?
classy
« Reply #24 on: Fri, 18 August 2017, 11:49:08 »
classy
Pick one.
« Reply #25 on: Sat, 28 October 2017, 21:29:35 »
Added a short-throw actuator - 8-way gate - 2lb spring - detachable stick - cleaned and lubed w/ high friction silicon grease - new wiring harness and cabling inside - some pretty gold buttons and feet - EVO '15 exclusive Sanwa Denshi wooden battop .... wound up costing much more than $200 in the end  :))
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #26 on: Sat, 28 October 2017, 21:44:15 »
Looks great...my Panthera has been collecting dust
« Reply #27 on: Sun, 29 October 2017, 12:31:18 »
load up some classic guiltygear xx #reloaded..
hahahahaha
Offline digi
  • elite af tbh
« Reply #28 on: Sun, 29 October 2017, 12:32:42 »
I'm actually surprised there aren't more fightstick people on GH considering we're into mechanical switches and video games.. fun stuff
Offline digi
  • elite af tbh
« Reply #29 on: Sun, 29 October 2017, 12:34:41 »
Yes, the old Hori was good until they sold to TP's people in Chiner.
« Reply #30 on: Sun, 29 October 2017, 13:16:42 »
sanwa is made by Tp's people too..
Offline digi
  • elite af tbh
« Reply #31 on: Sun, 29 October 2017, 13:18:58 »
Japanese?? It's starting to make sense now (Ramen, etc.)
« Reply #32 on: Sun, 29 October 2017, 14:52:07 »
Nawh.. Tp born wit gold stickerz all over every component.
Offline KetchyKech
« Reply #33 on: Sun, 29 October 2017, 15:11:05 »
We need a post your fightstick thread, ala SRK--I had a custom made years ago that I still use to this day. (Original Sanwa Flash optical  :p) Im thinking of throwing in a brooks pcb soon.  :thumb:
Offline digi
  • elite af tbh
« Reply #34 on: Sat, 11 November 2017, 10:09:13 »
Bought the 2017 seimitsu ls-32 for my panthera and some colored (racist) plungers...I'll get some pic's up soon once the parts come in.
« Reply #35 on: Sat, 11 November 2017, 16:08:22 »
nice dude, looking forward to pics
we really should start a post your fightstick thread
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #36 on: Mon, 13 November 2017, 18:02:57 »
You should have entered this into KOTM last month  :)) it looks awesome!
Offline digi
  • elite af tbh
« Reply #37 on: Fri, 01 December 2017, 20:23:19 »
« Last Edit: Tue, 05 June 2018, 11:08:45 by digi »
« Reply #38 on: Sun, 03 December 2017, 11:52:38 »
IMHO,  fighting games should be installed on OLDER gen motherboards Pre-sandybridge.. (IF POSSIBLE)
If you look at the dpc latency of older boards,  1-10..  vs the best gaming boards out today, 50-150.
Re: Post Your Fightsticks!
« Reply #39 on: Tue, 05 December 2017, 02:43:17 »
Definitley not under $200 but here we go :)
Razer Panthera w/ Seimitsu LS-32-1 and colored plungers, the over-sized ball is actually really comfortable, I think I like it.
On the TE2+ I'm putting an kowal over-sized actuator on the stock JLF, using the stock spring. I tried the 2lb spring and it's too heavy for me..
Fun stuff.
looking nice, calming color scheme. you gonna get some custom artwork and how are you liking the oversized actuator?
« Reply #40 on: Tue, 09 January 2018, 08:37:35 »
Oh, hey. There's a thread.
Was thinking of getting the VLX Kuro but maybe going for the Etokki Sanwa instead.
« Reply #41 on: Wed, 21 March 2018, 20:29:39 »
Offline JP
« Reply #42 on: Wed, 21 March 2018, 20:43:31 »
Why does she have a flight stick?  :rolleyes: Nevermind, don't answer that.
About Me | The Collection
« Reply #43 on: Wed, 21 March 2018, 20:57:29 »
she?
i have a qanba drone. i suck ass at fighting games
Offline SeedyOne
« Reply #44 on: Tue, 24 April 2018, 03:27:10 »
I haven't competed in years (2010 EVO) but I had a lot of fun building my fightsticks back in the day. Some of the stuff you guys can do these days with parts from Japan and stuff is amazing so mine are pretty basic in comparison. That said, great idea for a thread!  :thumb:
My SFIV Balrog inspired Hori. Basic Sanwas and a CF knob.
And my dual-modded TE (PS3/360) with custom etched plexiglass and a second printed layer for the red (eyes/logo). I'm a bit of a metal-head and big fan of the artist Giger (Alien movie franchise) so that's "Birth Machine" on the left and Vic Rattlehead from Megadeth down in the corner. An odd mix, but it worked out.
Closeup of the etching/layers
Offline KetchyKech
« Reply #45 on: Sun, 24 May 2020, 10:22:28 »
had some extra OG holy pandas (tribosys 3203) so i when i realized it was possible to solder them onto the little paradise arcade shop pcbs, i had to try
its amazing  ;D
Offline Darthbaggins
  • PC Cannibal
« Reply #46 on: Wed, 27 May 2020, 08:57:00 »
Now I want to build a fight stick, especially seeing the switch mod option - those would look awesome w/ the laser switches (of course with the right setup theme)
Offline KetchyKech
« Reply #47 on: Wed, 27 May 2020, 09:32:08 »
Oh yeah ! OBS MX is the best way to go.The other drop-in hotswap buttons are supposedly wobbly and have problems registering a button press.
The buttons feel so much better now, it really makes the stock sanwa pale in comparison.
They can do LEDs too but i believe you have to solder in your own resistors.
Offline SeedyOne
« Reply #48 on: Wed, 27 May 2020, 22:12:23 »
Seriously, I'm half tempted to mod my old sticks now that my old hobby has bled into my newer one with MKs. Only problem is, I'm not into any of the current fighting games so they'd just be for decoration  :p
  • PC Cannibal
« Reply #49 on: Thu, 28 May 2020, 10:04:14 »
Just saw Razer added a main cover I'd love to have to their fight stick
