Author Topic: HHKB - full buildout?  (Read 4212 times)
Offline q1w2e3r4t5z
« on: Tue, 15 August 2017, 06:06:18 »
Over the last months I went from my vanilla Type-S to the following:
- BKE domes
- Purple RF Sliders
- Hyperspheres
- HiPro
- Hasu BT controller
and I still feel that it needs a decent case or something that makes it a bit more, you know, endgame-y? I know that the true endgame doesn't exist an bla, but I'm on the lookout for something that makes me feel like "WHOA!" again... I tried lots of different switches/boards and I always stuck with my trusty HHKB so there's no real chance I'm going to switch to another board soon.
Nevertheless, I just wanted to see if there is a mod that I haven't have tried yet or if some genius came up with another great idea of improving this experience :)
Offline dgneo
  • Supervillain
Re: HHKB - full buildout?
« Reply #1 on: Tue, 15 August 2017, 06:34:53 »
- Purple RF Sliders
- Hyperspheres
You don't need both of these, just the purple sliders w/ the silencing rings. The hyperspheres would be for stock sliders.
Offline q1w2e3r4t5z
« Reply #2 on: Tue, 15 August 2017, 06:36:10 »
- Purple RF Sliders
- Hyperspheres
I bought the sliders separately w/o the rings
Offline dgneo
  • Supervillain
« Reply #3 on: Tue, 15 August 2017, 06:37:47 »
- Purple RF Sliders
- Hyperspheres
Any reason the seller separated them?
Offline q1w2e3r4t5z
« Reply #4 on: Tue, 15 August 2017, 06:38:34 »
- Purple RF Sliders
- Hyperspheres
Nope, but I was fine with that since I had the HS still laying around
Offline Petch
« Reply #5 on: Tue, 15 August 2017, 08:16:18 »
Threads like this make me wonder if it's all placebo, and if someone started out on a modded keyboard and went to stock they'd be all "whoa this is great"
Offline kmba
  • Formerly tameone
« Reply #6 on: Tue, 15 August 2017, 08:46:55 »
From type s.. to hypersphered?  why exactly?
There are no replacement cases.  You could lube it though.  And do you want to sell me your type s sliders?
keyboards.
« Reply #7 on: Tue, 15 August 2017, 09:25:45 »
yea, also, you definitely don't want hyperspheres now that they have the $25 flat rings version
Hypersphere is a major major rip-off.
That said,  why are you even doing all this when you can just buy the Type s ??
Offline kmba
  • Formerly tameone
« Reply #8 on: Tue, 15 August 2017, 10:04:42 »
He said he has a type s!!
keyboards.
Offline killyou
« Reply #9 on: Tue, 15 August 2017, 12:30:16 »
I think stickerbombing HHKB with $100 dollar bills would have the same psychological effect.
« Reply #10 on: Tue, 15 August 2017, 19:22:08 »
what ?
so he has a type s,  then bought hypersphere?
//Facepalm..
Offline 0100010
  • Not Sure
« Reply #11 on: Wed, 16 August 2017, 17:46:20 »
Wasn't there a short run of CNCd aluminum HHKB cases at one point?
Offline kmba
  • Formerly tameone
« Reply #12 on: Thu, 17 August 2017, 09:32:21 »
There were prototypes, but I don't think it actually "ran".  It was cancelled because it sucked  :p  Horrible pinging on key presses, and damned ugly.  Alu case for hhkb is much more tricky than other topre boards that have metal plates, because you can just swap the plate.
keyboards.
Offline ejewell89
  • 4ever Smol
« Reply #13 on: Thu, 17 August 2017, 12:23:59 »
Rama's ig has a prototype plate, not sure how it would work but i really hope someone attacks the cnc aluminum case thing. would be a very nice change up.
for what its worth. i took a dremel to a broken hhkb case and pcb and put them in a fjell. the controller board made the plates sit way too high, looked silly. plus none of the screw holes lined up of course. but in my mind i pictured it and it was glorious.
