Author Topic: Would Ducky One RGB white be the same white as the Nintendo 3ds?  (Read 2344 times)
Offline dman777
« on: Tue, 24 October 2017, 10:10:12 »
I have a white Nintendo 3DS and I like the way it looks with the blue LEDS. I have always been a Ducky fan. I was thinking about buying a Ducky One RGB that is white.
Does anyone know if  the white plastic of the Ducky One RGB be the same shade as the Nintendo 3DS? Or would it be a cream like white.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: Would Ducky One RGB white be the same white as the Nintendo 3ds?
« Reply #1 on: Tue, 24 October 2017, 10:32:40 »
Idk man, gonna buy both and let you know.
Will keep you posted!
Online tp4tissue
« Reply #2 on: Tue, 24 October 2017, 13:43:16 »
the ducky pans toward grey chalk white..
The ntendo is pearl white.
Describing what it'll look like with words wouldn't be accurate
HOWEVER, I can guarantee you they are NOT remotely the same white..
Offline Duckyreddy
  • Better skadoodle, poodle.
« Reply #3 on: Tue, 24 October 2017, 13:58:23 »
I have a Ducky One in White sitting in front of me right now, I can say that it is a very plain shade of white, not cream.
So very similar indeed but not sure if it's the same with the 3DS's white as I don't have one to compare.  :D
Hope that helped.
Ducky One Cherry MX Silent Reds
Leopold FC660M MX Blue
Logitech G403/ Razer Naga 2014
Offline dman777
« Reply #4 on: Sun, 05 November 2017, 22:13:48 »
Thanks for the replies. By any chance, does anyone know if the iKBC F108 RGB white would be closer to the Nintendo 3DS white?
Offline Duckyreddy
« Reply #5 on: Sun, 05 November 2017, 22:26:00 »
The whites should be very similar, but not identical.
Do you want to completely colour match the 3ds and your board?
Another option could be custom painting it and getting it to match completely and even mimic the identical finish.
An all white keyboard is hard to keep clean, mind you.
Looks spectacular, but only when it's spotless.  :p
Online HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #6 on: Sun, 05 November 2017, 22:32:08 »
Both have almost the same white shade in my POV  ;)
