Author Topic: Lightest switches possible  (Read 20672 times)
Offline tauburn
« on: Thu, 09 November 2017, 23:50:50 »
I currently am using a keyboard with gateron yellow switches that i installed Korean 55g springs which to my knowledge are the lightest springs available. I still feel like it could be lighter. Overall this is the best setup i have had so far, but the way i like to type is with a very light touch. i still find myself not actuating on some presses now and then. i want it to feel like there is basically no resistance from the keys at all. is there anything lighter?
Offline FreeCopy
Re: Lightest switches possible
« Reply #1 on: Fri, 10 November 2017, 01:07:27 »
Gateron clears are rated 35g actuation. You can also order springs rated at 35g.
Gateron clear switches plate or pcb mount
35g Stainless steel springs
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Fri, 10 November 2017, 02:33:47 »
Aside from microswitches, which you can get in 10 gf or less, the lightest KEYBOARD switches I know are Fujitsu magnetic reed. Those things put up almost no resistance whatsoever.
Offline subcat
« Reply #3 on: Fri, 10 November 2017, 02:35:26 »
A 25g Topre variant exists
Offline ygor
  • eat a butt, monkey lord
« Reply #4 on: Fri, 10 November 2017, 02:47:28 »
I used 35g Cherry Silver Speeds for a minute. Still use 35g for CS:GO keys. Is very najs.
Offline chyros
  • a.k.a. Thomas
« Reply #5 on: Fri, 10 November 2017, 05:13:52 »
If you remove the domes, they become <5 gf switches xD .
Offline Waateva
« Reply #6 on: Fri, 10 November 2017, 10:43:47 »
Serious gamer here, watch out for this guy!
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #7 on: Fri, 10 November 2017, 12:52:20 »
He 360 no scoped this thread
Offline ygor
« Reply #8 on: Fri, 10 November 2017, 14:32:51 »
it's all tru af
don't @ me
Offline Waateva
« Reply #9 on: Fri, 10 November 2017, 16:03:40 »
it's all tru af
don't @ me
Don't tell me what to do, you're not my dad.
Offline ygor
« Reply #10 on: Fri, 10 November 2017, 16:06:09 »
it's all tru af
don't @ me
i think you better have a talk with yer mother
Offline klennkellon
  • I like bottoming out
« Reply #11 on: Fri, 10 November 2017, 17:42:35 »
Long time ago here I saw a thread where someone modified a rubber dome or scissor switch board to be extremely low force. If anyone could find it that would be great.
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #13 on: Fri, 10 November 2017, 19:00:38 »
In terms of conventional switches, either 35g Topre clones or MX Speed Silvers (or another low actuation distance switch, like Kailh Speeds) with 35g springs would probably be your best bet.
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline Leslieann
« Reply #14 on: Fri, 10 November 2017, 19:37:19 »
Based on my experiments, for MX switches these are the lowest limits you can reasonably go.
This is for RELIABLE, non-mushy operation without spending time fiddling to get them to work.
25-30g linear
30-35 tactile
40-45g click/tactile
Yes, if they are worn in they can go a little lower, but passing these numbers leads to inconsistency. Using really good lube can lower them 3-5g and still work reliably. Keep in mind, lighter springs will feel slightly more mushy, and lube, which can make lower rates work, can also make them feel mushy but can also become more crisp as they work in.
The JB's on the Almost-A-Filco are vintage Cherry blues with clipped and lubed springs and switches (I lube the spring pads), they rate about 40g (using nickles) and are very crisp, however, getting them there consistently was a challenge and some lesser used keys (such as scroll lock) are still not crisp as they rarely get used. By comparison, my stock Outemu blues in the Magicforce using 60g are SUPER crisp, super snappy and totally consistent across the board.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline ander
  • I type, therefore I am
« Reply #15 on: Mon, 13 November 2017, 04:48:36 »
Wouldn't the lightest switches be no switches?
Mini Wireless Projection Virtual Bluetooth Laser Keyboard (Amazon, $28.50)
Offline AMongoose
  • happy workman user
« Reply #16 on: Mon, 13 November 2017, 05:32:50 »
That projected on a liquid.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #17 on: Sat, 18 November 2017, 04:22:02 »
Someone built a stenographers mini ergo split that was at the philly keycon meat... that thing what insane... it might as well been like there was no spring in the switch.
-Dana
« Reply #18 on: Sat, 18 November 2017, 04:47:32 »
Cherry MY with the coiled springs removed -- only the small leaf springs remaining. 20-25 cN.
Offline chyros
  • a.k.a. Thomas
« Reply #19 on: Sat, 18 November 2017, 05:20:05 »
Those are technically also the heaviest switches ever made :p .
Offline ander
« Reply #20 on: Sun, 19 November 2017, 03:19:52 »
Not if you project them on Jello.
« Last Edit: Sun, 19 November 2017, 05:32:44 by ander »
Offline rich1051414
« Reply #21 on: Sun, 19 November 2017, 08:40:12 »
Hilarious, but a massive improvement.
« Reply #22 on: Sun, 19 November 2017, 08:50:50 »
Or don't even use a computer..
Just go do that outside thing that all the normal people do..
Offline ander
« Reply #23 on: Sun, 19 November 2017, 09:59:51 »
Or don't even use a computer... Just go do that outside thing that all the normal people do..
What? Shiver?
Offline daskeybo
« Reply #24 on: Sun, 19 November 2017, 10:16:47 »
Offline chyros
  • a.k.a. Thomas
« Reply #25 on: Sun, 19 November 2017, 10:40:21 »
Believe it or not, I've LITERALLY contemplated it xD .
« Reply #26 on: Sun, 19 November 2017, 17:35:51 »
What? Shiver?
yea, they weird like that..
Offline Doofy
  • I'm from Scotland and I like Keyboards.
« Reply #27 on: Tue, 21 November 2017, 13:42:03 »
Lightest I've managed to try is 35g linears and damn, that stuff be light af! I struggled with choices for a while but I've recently settled on Gateron Browns, light enough for my taste and has the feedback I desire without being an obnoxious click. Just remember, lightest possible may seem like a good idea but it can honestly be like typing on feathers, its not always practical. Don't let this discourage you though, if that's what you want then I'd probably suggest Gateron Clears, I hear they are nice this time of year  :cool:
Offline ander
« Reply #28 on: Wed, 22 November 2017, 19:00:57 »
What? Shiver?
Ah, sorry, that's what people would do outside this time of year here in Canada.
Offline Macsmasher
« Reply #29 on: Tue, 28 November 2017, 21:40:01 »
I also prefer light keys. My favorite board is a Realforce 87U variable. Pinkie fingers are 30g and stronger fingers are 45g. If you're a touch typist, you won't notice the variable key weighting and it's still quite tactile given the light keys. Most here prefer the Realforce 55g (which I also have), but it's too stiff for my typing style for extended periods. At times I still use the 55g for coding because I'm not constantly typing. It's fine for short bursts and when using a lot of keyboard shortcuts.
« Last Edit: Thu, 30 November 2017, 21:56:09 by Macsmasher »
Offline sennin32
    • Doyu Studio
« Reply #30 on: Thu, 30 November 2017, 06:10:14 »
Gateron clear 35g!
Offline ander
« Reply #31 on: Thu, 30 November 2017, 20:07:59 »
I've heard about some of the things you've contemplated, and all I can say is, we're lucky this is a message forum and not a club meeting.  :?D
Offline SamirD
« Reply #32 on: Fri, 01 December 2017, 00:22:55 »
I look forward to the video review!  And try it with orange jello, because orange just tastes better.  :p
Offline rich1051414
« Reply #33 on: Sat, 02 December 2017, 13:02:49 »
The lightest switch I have tried were Xmit hall effect with the light spring. It felt even lighter than gateron clears since there is basically no slider friction. It was actually unnerving to be honest. Not used to being forced to hold my fingers up as the keys are actuated by the weight of them.
Offline Giorgio
« Reply #34 on: Sat, 02 December 2017, 13:55:52 »
I've tried to like switches lighter than reds, the problem is that you'll not be able to rest your fingers on the keyboard without incurring in an accidental press.
Offline Duckyreddy
  • Better skadoodle, poodle.
« Reply #35 on: Sat, 02 December 2017, 14:10:20 »
Yes, and the number of typing errors...
Ducky One Cherry MX Silent Reds
Leopold FC660M MX Blue
Logitech G403/ Razer Naga 2014
Offline SamirD
« Reply #36 on: Sat, 02 December 2017, 18:50:34 »
I just saw the video review of the projection keyboard and sadly jello was left out although there was water, bacon, cabbage, baguettes, and even dead octopus on wet newspaper.  :))
