Author Topic: I need to upgrade my laptop wireless card  (Read 7887 times)
« on: Thu, 23 November 2017, 08:43:21 »
I have an old laptop (Acer Aspire 5534 from 2010) that I use infrequently but would like to keep in service for another couple of years if possible.
The stock factory card is an Atheros Ar5b93 T77h047.31 LF and I would love to find something cheap on ebay to replace it.
It does not have to come up to 2017 bleeding edge standards, but the original has become dog-slow.
Can anybody give me some solid suggestions, and not just guesses?
- D Trump 2026-10-24
Re: I need to upgrade my laptop wireless card
« Reply #1 on: Thu, 23 November 2017, 08:45:32 »
Usb wireless dongles are very cheap you might try one of those
« Reply #3 on: Thu, 23 November 2017, 18:10:27 »
I eat meat and cheese, and even seaweed, but never wifi.
USB dongle is a great idea.
Offline Leslieann
« Reply #4 on: Thu, 23 November 2017, 18:26:26 »
That card is already 300mb, most of the tiny usb ones run at that or less, to go faster you either need the stick type or a base station. Also the USB ones tend to use more power so you really want an internal one if you want your battery life to remain.
Look into the Intel 7260 (Ebay $10-$30, Amazon $15-$30).
Beware, there are several versions, some with bluetooth, some without, some are wireless N, some are AC. You also need to make sure it has the two screw holes instead of the notch.
Skip the Intel 62** series, some have had issues.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #5 on: Thu, 23 November 2017, 21:20:18 »
I  doubt it's a wifi card problem fohat even has.. hahahaha
probably just a case of n00bness.
Fohat haz SSD, and Clean Windz installation ?
« Reply #6 on: Fri, 24 November 2017, 02:58:53 »
it's possible for wifi cards to wear out, but rare, because it'd have to be constantly transmitting. few people do bulk data over wifi.
i would reformat and buy an ssd first.
Offline Leslieann
« Reply #7 on: Sat, 25 November 2017, 05:44:00 »
He didn't mention it having a problem, only that he wanted an upgrade.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #9 on: Sat, 25 November 2017, 11:57:15 »
Nevermind, googled,  athlon L310.     641 passmark
If it is this cpu,  NOTHING will make this computer a joy to use.. Not even an SSD upgrade.
It's theoretically OK-ish if you install Windows XP on it.  But then you must use a samsung or intel ssd which have manual trim toolbox software..
IMHO, not worth messing with.
Nothing under 3500-4000 passmark is worth fixing up/ using.
Just buy a used lenovo T420..  LIGHT years faster.. and only ~$180-200ish
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #10 on: Sat, 02 December 2017, 00:53:12 »
I have been telling myself/family that i'm going to get around to wiring the house with cat6... but until then i'll just use a USB wireless on my desktop. That was like 7 years ago.
I have burned through a few of them and right now the one i'm using i bought last year and i've just recently started seeing the signs that its on its way to the trash (disconnects from the usb controller during heavy use). Its been pretty good though considering how many hours of pegged use it gets. Its this one from Panda 300mbps N . I just picked up another one for my 3D printer PC which is going out in the garage which is on the other side of the yard... and it is much better: Ourlink 600mbps long range dual band
« Last Edit: Sat, 02 December 2017, 00:55:55 by OfTheWild »
-Dana
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #11 on: Sat, 02 December 2017, 01:55:15 »
I second one of these. I bought one when my wireless card crapped out on my laptop, and then used it again for my first PC about six years ago. Worked very well and some of them come with a short cable so you can either have the dongle sticking straight out like a USB stick or on a small stand you can put somewhere away from the device to give you better signal.
« Reply #12 on: Sat, 02 December 2017, 03:39:26 »
You guys are on the right track had fohat's problem Actually been the wireless..
But around firefox 2x or so, the browser cpu requirement became quite significant.. this was 7 years ago..
The,  athlon L310 in fohat's laptop is almost certainly the more likely culprit of (perceived slowness).
