Author Topic: Help Re-Wiring BTC-5339R  (Read 2435 times)
Offline GTawesomesauce
« on: Sun, 03 December 2017, 16:07:36 »
Hello! I'm new to the forum, so don't blast me if this is in the wrong place :(. Anyway, I tried converting my BTC-5339R to PS/2 and found that the wire and the PCB have this cord attached to them. Are these important (and most importantly possible) for the conversion? Thanks in advance! (P.S. I don't wanna buy an adapter cause that's the easy way out ;D)
Re: Help Re-Wiring BTC-5339R
« Reply #1 on: Sun, 03 December 2017, 16:10:17 »
Forgot to add the attachment, silly me..  :D
Offline engicoder
« Reply #2 on: Sun, 03 December 2017, 16:27:43 »
Looks like a grounding wire for the shield in the cable. It helps reduce interference. You can probably get way without it.
« Reply #3 on: Sun, 03 December 2017, 16:32:43 »
Sorry, I should've clarified :eek:, the PCB and cord both have their own one of these. I did a test on the one for the cable, and apparently it attaches to the perimeter of the 5pin connector?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Sun, 03 December 2017, 17:06:03 »
It's tge connector ground. I suspect you'll probably need to properly ground both considering foam and foil keyboards are capacitive. I've had several instances of capacitive keyboards failing to function because I didn't tighten the screws that held the grounding wires all the way, even though they clearly made contact with the chassis, apparently that wasn't good enough!
« Reply #5 on: Sun, 03 December 2017, 17:12:02 »
Is there any possibility of doing that through the PS/2 port?
« Reply #6 on: Sun, 03 December 2017, 17:42:05 »
connect to ANYTHING that's earth ground..   got to have the right cable, some don't have ground/shield wire.
