Author Topic: How get Tip Off...... Halp !!  (Read 2097 times)
« on: Fri, 16 March 2018, 16:46:36 »
1st thought is,  Soak the tip in hot water ?
2nd thought.. BURN IT w/ Fire!!
3rd thought...  Gekhak Xperts.. !!
I know with bigger Gears I'd typically go with fire,  but i don't know if this type of attachment has some sort of issues with heat.
But in this case, there's not alot of clearance , and i definitely don't have a puller that small.
191747-0
Re: How get Tip Off...... Halp !!
« Reply #1 on: Fri, 16 March 2018, 17:17:00 »
Ah, screw it..
Just gonna wing it with some strategic-tissue-paperand pliers..
« Reply #2 on: Fri, 16 March 2018, 17:20:22 »
Tip is off..  feels good..
I ordered a replacement motor on eby,  's a good thing this shaver uses a common motor..
Offline JP
« Reply #3 on: Fri, 16 March 2018, 18:01:35 »
Just the tip?
About Me | The Collection
« Reply #4 on: Fri, 16 March 2018, 20:36:19 »
Just the tip?
I cut the base off and managed to fix the motor by cleaning leaked electrolytics which covered the brushes...
But now I can't get the Tip all the way down the shaft..
« Reply #5 on: Fri, 16 March 2018, 21:45:23 »
Until I saw the picture, I wondered what he was trying to get the tip off :))
