Author Topic: Are Hand Stands Necessary.. ??  (Read 2783 times)
« on: Sat, 07 April 2018, 15:25:13 »
Being able to do at least -a few- pullups/chinups  is critical,
because who knows when one may fall out of a building or cling for dear life on a cliff , pushed/or otherwise..
But, what about the Hand Stand ?
Any reason why this would be a useful  ?
Re: Are Hand Stands Necessary.. ??
« Reply #1 on: Sun, 08 April 2018, 05:08:33 »
If you're trapped in a cave/collapsed building and there's a heavy stone blocking an exit about five feet off the floor you could handstand underneath it with your legs bent and extend them to push it out the way because legs are stronger than arms?  Though if you can put your feet on the rock you don't really need to balance, so not sure that counts as a handstand....
One handed?  That's just showing off :))
« Reply #2 on: Sun, 08 April 2018, 06:39:23 »
It's harder than it looks on youtube..
I've been trying all yesterday and just kept falling over. !!
« Reply #3 on: Sun, 08 April 2018, 10:15:53 »
You are working up some of the same muscles as you would use in pole-vaulting over obstacles that are higher than the length of your pole.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #4 on: Sun, 08 April 2018, 10:22:03 »
Every time you think about eating meat, I demand you do a handstand until said urge goes away.
You'll get ripped like dood in pic.
« Reply #5 on: Mon, 09 April 2018, 07:32:32 »
I think i'm going to put this on hold for now,  my flanks hurt from falling over so many times.
