Author Topic: How would you go about creating this dream keyboard  (Read 3357 times)
Offline rhizo
« on: Sun, 15 April 2018, 15:39:27 »
Hey, I haven't been on here for a while, but I've got a question that I can't seem to answer by myself.
So what I'm looking for is basically this exact layout:
With this spacebar design in the place of the above:
It would also need to be programmable, as the left space key would end up being a sort of hold to switch layer key (or just a normal switch layer key), so you could do left space + j for a different key for example. There are a ton of DIY kits and stuff out there, but I was wondering if this is possible to even get close to without too much effort. Even that first layout I showed would be good enough to be honest, but I can't find it anywhere. I'm from the UK, if that makes sourcing any more difficult.
Thanks,
Offline TalkingTree
    • My projects
Re: How would you go about creating this dream keyboard
« Reply #1 on: Sun, 15 April 2018, 15:41:40 »
I'm not entirely sure, for I don't own the board but I believe the DZ60 should cover your layout.
« Reply #2 on: Sun, 15 April 2018, 15:46:09 »
Unless you want to drill and file the slots for the switch and stabilizer.
The only other way is to get a custom cut plate.
you don't need a custom pcb,  you can just drill holes  in an existing pcb and wire it up manually.
Again, manual drilllng/filing is an option if you're confident in your own dexterity.
Offline rhizo
« Reply #3 on: Sun, 15 April 2018, 15:56:02 »
Ah that gets pretty much as close as I've seen.
Not sure if I'm up for that, seems a bit beyond me. Even soldering the switches I'm not too sure about. I'm assuming you'd recommend against using something like https://www.aliexpress.com/item/DZ60-Custom-mechanical-keyboard-PCB-60-keyboard-support-arrow-key/32824638057.html , they seem to have an assembly service too.
« Reply #4 on: Sun, 15 April 2018, 17:08:05 »
You can buy those boards..
But doing THAT many switches is a PITA if you're not really -into it- hahahaha..
It's a valid option..
Watch some soldering videos,  it's not hard,
Offline rhizo
« Reply #5 on: Sun, 15 April 2018, 17:39:57 »
Yeah, I can actually solder reasonably well but I can't be bothered really. I'm thinking about perhaps this board and just dealing with the ansi layout. Not really the best but it fills all my other criteria.
http://groupbuys.mechboards.co.uk/shop/z62-kit-group-buy/
