Author Topic: Dehumidifier not Wurkn'  (Read 3008 times)
« on: Wed, 02 May 2018, 10:21:01 »
Update: Fixed..
Problem was the Potentiometer..
It should be @ 50k ohm peak,  Only reads 1k peak..
That's why the compressor wasn't turning on..
I only figured this out after getting tired of hammering the compressor for 30 minutes.
Prior, I chked every capacitor and relay,   what a waste of time.. 3 hours later..
______________________________________________________
Circuit board is fine. Capacitors are fine..
Fan will turn on,  but the Compressor won't start.
Soooooo.. Going to Hit it with a Hammer..
Now, the only question is..
Is it better to Hit it from the side ?  or top down,  or Diagonally??
Re: Dehumidifier not Wurkn'
« Reply #1 on: Wed, 02 May 2018, 10:24:42 »
I think on top.
Offline emenelopee
  • *klomp klomp klomp* I step on your house 🦖
« Reply #2 on: Wed, 02 May 2018, 10:39:00 »
Percussive maintenance.
Have you tried vegetables?
Offline AMongoose
  • happy workman user
« Reply #3 on: Wed, 02 May 2018, 10:40:29 »
The humidity is fine. Your body needs water. Embrace the humidity.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #4 on: Wed, 02 May 2018, 10:40:36 »
« Reply #5 on: Wed, 02 May 2018, 10:47:27 »
Come on now guys hitting it with a cucumber just isn't going to be the same as using a hammer.
Offline emenelopee
« Reply #6 on: Wed, 02 May 2018, 11:07:35 »
Human teeth are not designed for hammers, cucumbers are full of green which is all the body needs to cure cancer.
« Last Edit: Wed, 02 May 2018, 11:10:00 by emenelopee »
« Reply #7 on: Wed, 02 May 2018, 11:40:38 »
Tp4 am finally connecting with Other Humans..
« Reply #8 on: Wed, 02 May 2018, 11:46:27 »
Update: Fixed..
Offline clasicks
  • Formerly KeyboardUser4
« Reply #9 on: Wed, 02 May 2018, 11:49:39 »
pot fixes problems, eh
Offline JP
« Reply #10 on: Wed, 02 May 2018, 20:35:24 »
The veggies like the humidity though.
About Me | The Collection
Offline fanpeople
« Reply #11 on: Thu, 03 May 2018, 01:51:41 »
Come on now guys hitting it with an ORGANIC DILDO just isn't going to be the same as using a hammer.
FTFY
