Author Topic: cleaning a desk mat?  (Read 25794 times)
Offline HotRoderX
« on: Sat, 21 July 2018, 17:04:29 »
So I got a Godspeed deskmat was looking on best way's to clean them. Would just chunking it in the washing machine with some tide pods work are?
Offline Olumin
  • "Guy walks into a doctor's office..."
Re: cleaning a desk mat?
« Reply #1 on: Sat, 21 July 2018, 17:13:08 »
Dry cleaning perhabs?
Offline clik_clak
« Reply #2 on: Sat, 21 July 2018, 17:18:39 »
I just washed both my Godspeed and MX desk mats yesterday.
Wash in machine on delicate setting, cold/cold, medium spin and then let air dry. Do not use your machine dryer.
Both came out as good as the day they were new.
Offline fanpeople
« Reply #3 on: Sat, 21 July 2018, 18:09:51 »
Wow. Why did i not think of this. I usually spray it with bulk spray and wipe, rub it hard with a chux and then get the ****s when it does not work.
« Reply #4 on: Sat, 21 July 2018, 18:14:09 »
I wash mine in the shower using liquid detergent and a coarse sponge to rub it in. Then rinse and hang dry. Hang drying does not take that long.
Offline HotRoderX
« Reply #5 on: Sat, 21 July 2018, 18:58:07 »
thanks everyone will do! yea just like to keep mine clean you know.
« Reply #6 on: Sat, 21 July 2018, 19:00:39 »
I just put some tide powder on it wet..
and lightly Go at it with a tooth brush
Offline Aerizu
  • Professional Lurker
« Reply #7 on: Sat, 21 July 2018, 20:21:13 »
Exactly this. Warm water would also help.
« Reply #8 on: Sat, 21 July 2018, 21:04:06 »
MM...  recommend against warm water..
Depending on how well that glue is tacked..  it could more easily come undone with warm-ness
Offline ArchDill
« Reply #9 on: Sat, 21 July 2018, 22:19:57 »
I need to wash my black cherry mat... I have had it for a bit. It is getting crusty...
Offline exitfire401
  • The Force is Re/\l
« Reply #10 on: Sat, 21 July 2018, 23:40:47 »
Mine goes into the washing machine on cold and air dries. I've had my desklength goliathus since 2011 and haven't had any issue doing so. Probably gets washed 2-3 times a year.
