Author Topic: Fiberglass error in Tp's favor  (Read 3831 times)
« on: Fri, 05 October 2018, 18:59:02 »
Dat guy cutting rods in the warehouse is overworked..
Ordered, 20 feet of 1/8th inch thick fiberglass rod for $10.
Received 400 feet ..  20 units of 20 feet..
called CC, confirmed they charged me $10
This isn't the first time that dude messed up..  last time received 1and1/8th rod instead of 1/8th rods.
Offline kiwi99
  • that's a gnarly dookie
Re: Fiberglass error in Tp's favor
« Reply #1 on: Fri, 05 October 2018, 20:30:35 »
so whats all the fiberglass for? just stocking up for the impending fiberglass shortage of 2021?
« Reply #2 on: Fri, 05 October 2018, 20:32:07 »
Everyone could use a little m0ar fiber. !!
Offline p_blaze
« Reply #3 on: Fri, 05 October 2018, 22:06:37 »
Word
My ****s pop out like butter after chomping om a bit of this stuff every morning
« Reply #4 on: Fri, 05 October 2018, 22:17:11 »
Word
My p00p pop out like butter after chomping om a bit of this stuff every morning
Very high tensile strength..
« Reply #5 on: Mon, 08 October 2018, 19:54:43 »
GDI, the nylon and delrin rods are fine,  but the fiberglass rods are 0.04mm off spec.. Fffffffffff..
I'm so mad....
Offline kiwi99
« Reply #6 on: Tue, 09 October 2018, 14:47:49 »
I'm so mad....
0.04 off spec or 0.04 outside of tolerance, hopefully its the latter and you're not just being silly with your complaining :thumb:
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #7 on: Tue, 09 October 2018, 15:57:47 »
Building some sort of linear motion assembly?
« Reply #8 on: Tue, 09 October 2018, 16:38:40 »
tolerance is 0.02mm..  spec is 0.04mm off..
