Author Topic: Wiha or Bondhus ??  (Read 5676 times)
Offline JP
Re: Wiha or Bondhus ??
« Reply #1 on: Thu, 11 October 2018, 21:58:55 »
Both are good. No one company makes the best of every tool. Not all of Wiha's tools are made in Germany. I mix and match based on utility, quality, and value but I usually prefer Wiha.
« Last Edit: Thu, 11 October 2018, 22:06:11 by JP »
About Me | The Collection
Offline JP
« Reply #2 on: Thu, 11 October 2018, 22:04:08 »
For the krauts lets also throw in Wera and Felo into this discussion. For 'Merica there is Klein and Greenlee. I'm sure there are lots of others we could add.
Offline Leslieann
« Reply #3 on: Thu, 11 October 2018, 22:10:37 »
In this case it depends on your purpose.
One is more comfortable, the other has more leverage or lower profile.
Personally, I would take the Wiha, not because I think they are better but because not only can you turn it on it's side and get better leverage, or slide under things, but it has a ball end and a flat end. Ball ends are notorious for stripping fasteners and should never be your only option.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #4 on: Thu, 11 October 2018, 22:29:12 »
I will only be getting the Flats..
Have had too many FAILs with the ball end.. 'Never again.. !!
That ping, or krunk noise when the ball pops.. // shudder..!!
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #5 on: Fri, 12 October 2018, 05:14:44 »
I’m rarely impressed with the hype attached to products but I”m very impressed with the working end of Wiha screwdrivers. I’ve used many different brands and Wiha’s tips retain their shape and bite immeasurably better than any other brand i’ve used. I can’t speak to the hex wrenches pictured but have yet to regret buying a Wiha.
I don’t like the material choices they make for their handles though. They feel a little slippery in the hand and mar pretty easily.
Offline Unicorn_Systems
« Reply #6 on: Fri, 12 October 2018, 05:35:04 »
You need to try some Wera hex plus hex keys. Those won't snap. Well, they shouldn't unless you're undoing a seized fastener, in which case you'll need to use excessive torque and anything will probably snap.
Sent from my SM-G935F using Tapatalk
« Reply #7 on: Fri, 12 October 2018, 05:56:35 »
They don't seem to sell this in a set..  I guess that makes sense for high end..
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #8 on: Fri, 12 October 2018, 08:59:59 »
Been having no problems with my 65-part micro-bit set from Wiha. Been taking apart typewriters, keyboards, flashlights, calculators, V2 rockets... NO problem!
...So far...
Deutschland wins!
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #9 on: Fri, 12 October 2018, 10:24:26 »
+1 for Wiha
They've stood up to abuse which has ruined lesser tools.
