Author Topic: Sooo.. ah.. bathroom xhaust fan.  (Read 4226 times)
« on: Fri, 12 October 2018, 14:47:14 »
Took it apart, cleaned it..
Put it back in.. Notice suction isn't too good because the housing wasn't tight/sealed, some air blowing downwards.
Taped internal chambers up with Foiled Radiator tape.. Now suction is great..
HOWEVER,  it makes this wind-woofing Noise..
I can't figure out what's wrong..   It's such a simple box, in out.. the only difference is it has better seal now..
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
Re: Sooo.. ah.. bathroom xhaust fan.
« Reply #1 on: Fri, 12 October 2018, 14:54:36 »
Look further up the system, duct/vent to outside may be impeded causing suction sound change? If nothing in the actual fan unit has really changed but with an improved seal, it's probably blowing against something further up the line with more force than it used to.
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #2 on: Fri, 12 October 2018, 15:07:50 »
Hwhat in the hail is a wind woofing sound? Is it like wind whistling?
« Reply #3 on: Fri, 12 October 2018, 15:13:49 »
It's not like a Dog-Bark woof,  just like a wind howl but less high pitch.. and it's intermittent like a wooof wooof.. noise.
Offline sncbraxsc2
« Reply #4 on: Fri, 12 October 2018, 15:18:13 »
better seal = improved flow? Stronger velocity against the gate/filter or other impediment = whistle noise?
« Reply #5 on: Fri, 12 October 2018, 15:24:17 »
In one of my first apartments I had such a small bathroom with such a good seal in the room, that when you clenched your butthole while sitting on the toilet it would actually create enough pressure in the room to shake the door a little. It tripped me the **** out when I first discovered I could move the door with my sphincter.
« Reply #6 on: Fri, 12 October 2018, 15:36:46 »
Where are the physicists.. Is this possible. ??  Isn't NT already in equilibrium with the room once the door closes ??
« Reply #7 on: Fri, 12 October 2018, 16:25:58 »
Checked the pipes going into the attic..
They're clear,  Blasted with leaf blower from the inside.
Is it possible that it was designed to be leaky and have back pressure ?
Offline FrostyToast
  • Litshoard
« Reply #8 on: Fri, 12 October 2018, 16:29:34 »
TP, no need to be subtle.
Reading this, I now understand which "bathroom exhaust" you're talking about.  :rolleyes:
Take a Pepto-Bismol and you'll be fine.
Quote from: elton5354
« Reply #9 on: Fri, 12 October 2018, 16:33:03 »
Hahahahahahhahahahahaha
« Reply #10 on: Sat, 13 October 2018, 20:39:51 »
tp4 has a fan fitted there?
Must be uncomfortable when he sits down.
Offline typo
« Reply #11 on: Mon, 15 October 2018, 13:28:12 »
Get a Panasonic one. Not easy to install though.
« Reply #12 on: Mon, 15 October 2018, 15:12:13 »
Def gonna get the panasonic after this one breaks..  but that might be a while.. since these things don't break that often..
