Author Topic: Turn it off and on Again..  (Read 2668 times)
« on: Mon, 15 October 2018, 09:16:58 »
So, rebooted the router (software reboot) recently..
and for whatever reason cut-through-forwarding became disabled, (even though), the setting was unchanged (enabled).
For 2 days, Tp4 was only able to download 180Mbps.. instead of ~830Mbps..
Mistakenly thought someone was skivvyin' mah bandwidth..
Offline dgneo
  • Supervillain
Re: Turn it off and on Again..
« Reply #1 on: Mon, 15 October 2018, 10:13:44 »
thank you for this. had no idea what it is, did some research, enabled it on my router, now getting 600+ Mbps as opposed to 300Mbps.
edit: second test hit 785  ;D ;D ;D ;D
« Reply #2 on: Mon, 15 October 2018, 10:22:03 »
hahahahahahah.... You n00b you..
How could you have not noticed when you signed up and was getting half speed.
What router are you using.
