Author Topic: Hammer Drill. Thoughts ?  (Read 2922 times)
« on: Sun, 28 October 2018, 08:22:43 »
Home depot sale..
It's $379
You get the   Bigboy hammer drill (not the compact wimpy one),  a driver(useless),  The cordless circular,  AND 2x bonus 3ah batteries..
Thoughts ??
206335-0
Offline duckboi
Re: OKOKOKOK... Don't need this buhhhhh.. !!!!!
« Reply #1 on: Sun, 28 October 2018, 10:58:08 »
I think we've been over this before but I cannot imagine what TP4 will be doing with drills and other assorted power tools...  :eek: :eek:
The m0ar empty you feel,  the m0ar space for Keycaps..
Re: Hammer Drill. Thoughts ?
« Reply #2 on: Sun, 28 October 2018, 15:58:16 »
Tp4 no haz hammer drill yet..
Can't do concrete without hammer drill..
Offline FreeCopy
« Reply #3 on: Sun, 28 October 2018, 16:11:15 »
What type of concrete/brick are you trying to drill? What depth and hole size? That cordless will have limits compared to a larger plugin SDS type hammer drill. If it's around the house stuff that thing will be awesome.
That smaller impact driver is pretty damn handy. If it's the 3 speed that thing has an impressive ability to drive things as well as strip or shear fasteners or break bits if hit too hard. Level 1 is really easy and clutches out just under what you would be able to do with a hand screwdriver. A very safe setting for more delicate stuff. Level 2 is perfect for most everything. Been using mine on construction for over a year now and have rarely needed to go to level 3. Battery lasts surprisingly long, too.
For that price I'm pissed I had to buy mine at standard MSRP. If you price the batteries alone off the shelf they are worth more than the $379 being charged for the kit.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
« Reply #4 on: Sun, 28 October 2018, 17:13:23 »
Yeah, that looks like a great deal if you have a spare $400 laying around.
That same morning, the Financial Times revealed that for the past three years Russia has been helping Iran build a supersonic cruise missile capable of blowing our ships out of the water, and at an Iran/Russia/China summit with Iran’s president, Putin, and Xi in Bishek this week, Putin said he’ll continue to supply Iran with “the necessary goods” that can be used to kill Americans.
« Reply #5 on: Sun, 28 October 2018, 17:39:25 »
6 inch concrete..  need holez..
I'm looking at the pluggin version as well..  i mean, they're probably more powerful, buhhhh.. not as kewl...
Offline FreeCopy
« Reply #6 on: Sun, 28 October 2018, 18:15:52 »
I'm thinking less than 1/2" diameter you should be fine. My experience with the cordless has been up to 3/8" and no deeper than 3 or 4". More than that I grab the plug in.
The plug in will be much cheaper. They usually have a selector for hammer, drill, or hammer+drill so it will be just as versatile or more with what you can go through. The cords are rarely longer than 5-6ft so they become a hassle fairly quickly.
I'm assuming this is for home use so the cordless I think will benefit you much more, especially seeing what's in that kit and the price. Much more than that drill can handle and I'd suggest renting the drill from Home Depot or the like but that requires going to there in person.
Keyboards
