Author Topic: Diabro Blade 12"  (Read 2624 times)
Diabro Blade 12"
« on: Wed, 05 December 2018, 14:36:47 »
Just tested it out on new dws779 miter..
208375-0
Pros:
Smooth cutting..
Flawless finish, even with high cut speed.
Virtually no blowout bottom or back
Definitely no sanding required..
Cons:
Makes an extreme shrieking noise..  (Not sure if my blade is broken)
Extremely Thin plate.. ?!?!?
The vibration dampener must be a gimmick, cuz WTH, it's so high pitched..
Cost twice as much as other brands..
Offline SBJ
  • Tactile pls
Re: Diabro Blade 12"
« Reply #1 on: Thu, 06 December 2018, 04:49:55 »
That's nice and all but do you still have your fingers?
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #2 on: Thu, 06 December 2018, 06:19:22 »
I haven’t tried that exact blade but am surprised that it is so noisy. As a general rule, the smaller gullets from the greater number of teeth usually make the blade quieter. A miter saw’s blade will seem noisier than the same blade in a tablesaw. The blade noise is dampened by most of it being contained in the tablesaw’s body.
« Reply #3 on: Thu, 06 December 2018, 07:45:11 »
Yea I called up the Diabro peeps,  they said something may be wrong with the blade..
I tried several blades, hitachi , cheap overpeak, dewalt vanilla, none make this shrieking sound..
The noise isn't during the cut, only when free spinning..
Offline Little4Real
« Reply #4 on: Fri, 07 December 2018, 10:59:42 »
Wish I could use a saw without being squeamish
« Reply #5 on: Mon, 10 December 2018, 10:35:08 »
Zomg.. Did y'all know , can cut newspaper bundles on miter saw ?
Wow.. so easy..
