Author Topic: [IC] Fox Lab - Leaf 60 (GB start)  (Read 93255 times)
Offline yicaoyimu
Re: [IC] Fox Lab - Leaf 60
« Reply #200 on: Fri, 04 January 2019, 00:38:33 »
I need a polycarb board in my collection! Please make it happen  :))
Offline etong415
« Reply #201 on: Fri, 04 January 2019, 01:43:32 »
If you have the time to fully assemble a prototype, could you possibly post a typing video?
Offline ian13
« Reply #202 on: Sun, 06 January 2019, 09:53:44 »
Hopefully, this would support universal 60% PCB so we can choose whatever PCB we want to use as well as ease of replacement if anything happens.
But it would still be okay if you decide to have a proprietary PCB with a center port location.  :thumb:
I would just like to clarify some things:
     1. For the type of gasket, have you decided on the thickness as well as the hardness of the rubber that you will use?
     2. I am also a bit concerned on the sides of the plate (left and right) without the rubber gaskets. I hope the tolerances will be tight enough so that it won't touch the bottom and top halves of the case when fully
         mounted/screwed.
Hmm... Also, is it too early to ask for the timeline (at least rough estimate) of this gb? Slightly excited on that PC gasket-mount board.  :p
Anyhow, good luck!
Offline senter
« Reply #203 on: Sun, 06 January 2019, 11:40:04 »
Any more info on the gaskets?
The gaskets I'm testing are 1.5mm thick clear strips. The screws will go through the bottom case, one gasket, plate, another gasket, then the top case.
Offline senter
« Reply #204 on: Sun, 06 January 2019, 11:41:51 »
Another thing that would be interesting is if the weight is the same as the leaf 80. That way they are replaceable / swappable.
The weights are same.
Offline senter
« Reply #205 on: Sun, 06 January 2019, 11:50:33 »
         mounted/screwed.
Anyhow, good luck!
Thanks.
1.  The thickness is 1.5mm. Rubber strips are not as springy as rubber rings. I don't know how to measure it tho.
2.  It's not gonna happen at least for aluminum plates. I'll test the PC plates later. I assume there won't be any problems.
I'm planning to launch the GB before CNY and estimation of the shipping date is in April.
Offline Vigrith
« Reply #206 on: Sun, 06 January 2019, 15:27:25 »
Very nice, look forward to it!
Offline ian13
« Reply #207 on: Sun, 06 January 2019, 18:03:21 »
CNY is just around the corner! Looking forward to it!
Offline dantambok
« Reply #208 on: Sun, 06 January 2019, 18:06:06 »
Woah that means this will run very soon. Cant wait!
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline PikaJoyce
« Reply #209 on: Sun, 06 January 2019, 18:30:44 »
Also very interested in the PC version!
Offline hhkbp2
« Reply #210 on: Sun, 06 January 2019, 21:00:01 »
The prototype looks really nice. Would love to see its typing video.
Offline blizzara01
« Reply #211 on: Sun, 06 January 2019, 22:00:13 »
PC is more expensive than alu, right? Might try PC
Offline Vigrith
« Reply #212 on: Mon, 07 January 2019, 08:01:54 »
Boards that offer both generally have them at the same price point, though a couple well known manufacturers have stated PC is generally slightly harder to machine than aluminium.
Offline mnpq.raven
« Reply #213 on: Mon, 07 January 2019, 08:52:36 »
Is there an estimated quantity of units you're going to sell ? Interested in the board especially the Pc version and E-coating
Sent from my SM-G950F using Tapatalk
Offline ArchDill
« Reply #214 on: Tue, 08 January 2019, 07:47:52 »
Offline DJSwayde
« Reply #215 on: Tue, 08 January 2019, 07:53:04 »
Has it been decided whether a universal or proprietary PCB will be used?
60%: CannonKeys Bakeneko60
BUILD 1: Black | FR4 plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
BUILD 2: Black | 1upkeyboards π60 (pi60) PCB | 1upkeyboards FR4 plate | Akko Rosewoods | HammerWorks CRP R6 Egyptian Alphas kit & CRP R7 kits (40%, 60%, Spacebars, Stepped Modifiers) keycaps
 | GEONWORKS Frog Mini
Silver | HHKB | 4pplet Steezy60 (Alps) PCB | Custom SS plate | Alps SKCL Yellows | Canon S-14 & S-16S keycaps
| GEONWORKS LAUNCHER60
Silver | Custom PCB | Custom SS plate | Alps SKCL Creams | C.Itoh CIT224F & IBM 5140 keycaps
| LSJ Ares
Silver | Custom PCB | Custom SS plate | Alps SKCL Browns & SKCL Amber | IBM Multistation 5556-CC1 (TW) & P70 (ANSI-US, 06-89) keycaps
 | LZ CLS h
Silver | Custom PCB | Custom SS plate | Alps SKCM Creams | MET Micro Officer 6000 (R315-00) & Zenith Data Systems TurbosPORT 386 keycaps
| MONOKEI Kei R1
Standard Red | Aluminum plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G81-1291SAW & G81-3090SAQ (Schneider) keycaps
| SINGAKBD Unikorn R1
Black | Black aluminum plate | Cherry Retooled Blacks (TX 60g springs) | G80-3485LWNUS (Das Keyboard II) keycaps
| Wangus x KEZEWA Snake60 R2
Silver (re-anodized hot pink) | WKL | Custom PCB | Custom SS plate | NMB "Space Invader" (White one-eye linear [fourth generation]) | NMB RT-101 (NCD) keycaps
 | Weaston GSKT-00-Z
Silver | AEK HHKB | Aluminum plate | Alps SKCL Greens | Apple Extended Keyboard II (M3501, Taiwanese) & Standard Keyboard (M0116, US) keycaps
Pad: KBDFans KBDPAD MKII
Black | FR4 plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G80-3485LWNUS (Das Keyboard II) keycaps
| KBDMania KMAC Pad
Titanium grey | Aluminum plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G81-3090SAQ (Schneider) keycaps
| Leopold FC 210TP
White | Custom PCB | Custom SS plate | Alps SKCL Compact Greens & Alps SKCL Browns | C.Itoh CIT224F keycaps
| Momokai Aurora
Cherry Vintage Blacks (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
Topre: PFU Ltd. HHKB Pro 1 (PD-KB300BN)
hasu Alt USB controller | Topre Realforce 91UDK-G (NG02B0) & Realforce 103UB (SE42B0) keycaps
| PFU Ltd. HHKB Pro 2 (PD-KB400B)
hasu Alt Bluetooth controller | Purple sliders | 35g domes | Stock & Topre Realforce Taiwanese kit (dark gray) keycaps
| PFU Ltd. HHKB Pro 2 Type-S (PD-KB400WS)
4pplet SHKB Lite controller | 25g domes | Topre Realforce 87UW55 (SE08T0), Realforce 91UW (NE0100), Realforce Taiwanese kit (white) keycaps
| Topre Realforce 23U (WC0100)
Cipulot EC23U PCB | Purple sliders | SS plate (modified to allow for 24U) | 25g domes | JUKI Celavi keycaps
 | Topre Realforce 87UW (SE08T0)
Purple sliders | 30g domes | Sony BKE-9400A, MKS-8050, PVE-500, stock keycaps
| Topre Realforce 91 (NE0100)
Cipulot RF R1 8-9Xu PCB | 30g domes | JUKI Celavi & Topre Realforce 108UG-HiPro (YK0100) keycaps
Other: Apple Desktop Bus Keyboard (C658-4081) (CA)
Alps SKCM Oranges & SKCL Lock Cream
| Apple M0110A (US)
Beige | Vortex ViBE (US) (case installed inside) | Custom PCB | Custom SS plate | Alps SKCM Blues | Hewlett Packard HP Portable Vectra CS (US) & R/332 Instrument Controller (US) keycaps
| KUL ES-87
Black | Keygeek Su Color V2s (45g) | MW Heresy (with Gluttony & Envy kits) keycaps
| Zuoya HE30
Black | Hotswap: Keytok Novas / Wooting Lekker Tikken Mediums | Ranked POM keycaps
Collection
Offline juaninamilli
« Reply #216 on: Tue, 08 January 2019, 08:11:43 »
That looks amazing! Where did these images come from?
https://imgur.com/a/abfRyVH
Whew....
Offline ArchDill
« Reply #217 on: Tue, 08 January 2019, 08:14:27 »
Offline reidd
« Reply #218 on: Tue, 08 January 2019, 08:36:28 »
Definitely interested. Trying to decide on a color  :-X
Offline 8six753o9
« Reply #219 on: Tue, 08 January 2019, 08:42:20 »
Very interested in the PC version or maybe yellow if that option is available. Would it be possible to have a hhkb plate like this?
Offline mnpq.raven
« Reply #220 on: Tue, 08 January 2019, 08:56:34 »
Or leave the plate as is and not cutting the 2 corners would be also nice ! I think it'd be just as attractive
Offline cijanzen
« Reply #221 on: Tue, 08 January 2019, 09:21:38 »
+1 for this! That plate design would loook beautiful with PC. It might be too late but I’d throw in my vote for universal PCB even though it detracts from the aesthetic. At the same time a proprietary PCB would not stop me from entering the gb. Looking forward to seeing where this goes!
Offline appaboy
« Reply #222 on: Tue, 08 January 2019, 09:27:43 »
I need more polycarb in my life please!
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline dimo
« Reply #223 on: Tue, 08 January 2019, 09:56:07 »
If we could get some custom colored plates for the PC version, it’d look really good showing through the polycarb imo
Offline Visionaire
« Reply #224 on: Tue, 08 January 2019, 10:07:45 »
Wow, the PC version looking so nice.
Offline Dovan1405
« Reply #225 on: Tue, 08 January 2019, 10:17:00 »
okie i take one polycarb thanks.
Offline FunTyme
  • Formerly known as Edrylle
« Reply #226 on: Tue, 08 January 2019, 12:08:58 »
These look so nice. Might have to pick one up for myself
hbcp
Offline pixelpusher
« Reply #227 on: Tue, 08 January 2019, 12:18:03 »
Yes, the PC one looks great!  It just scares me to go with that option because I hear about stripped threads and loose screws.  Will have to think on it.
Offline asury
  • /u/adsury/
« Reply #228 on: Tue, 08 January 2019, 12:56:25 »
Wow is that Sidewinder’s PC plate? where did you get that from?
Regarding the Leaf60 PC, I’m also looking forward to pick one up if it’s available later
Grey Duck Sidewinder/GMK Hyperfuse Origins/MX Black retooled | Sage M60-A/GMK Camping/Holy Sky | LFK68/DSA Granite Alps/SKCM Orange Alps
Offline dado brat
« Reply #229 on: Tue, 08 January 2019, 13:05:05 »
looks promising. what is the weight on either of them with brass plate?
Offline ossetepo
« Reply #230 on: Tue, 08 January 2019, 13:16:45 »
Are you using threaded inserts for screws on the polycarb version, or are the screw holes tapped directly into the PC material?
Offline Bubblegum
« Reply #231 on: Tue, 08 January 2019, 13:44:42 »
That render green on the first page looks delicious :)
Offline Darknight00z
« Reply #232 on: Tue, 08 January 2019, 14:04:13 »
Underglow support for the PC please!!
Unless we can use the DZ60?
« Last Edit: Tue, 08 January 2019, 14:08:06 by Darknight00z »
Offline MxBlue
  • buy my keyboard
« Reply #233 on: Tue, 08 January 2019, 15:33:53 »
A few replies to cross-post from reddit:
I can provide a dedicated HHKB plate.
Two versions of proprietary PCBs with middle USB ports. The first version supports variants of MX layouts and WKL ALPS layout. The second version supports hotswap and dedicated HHKB/WKL layout.
« Reply #234 on: Tue, 08 January 2019, 16:12:05 »
MX and Alps? Oh no
Hotswap? Oh no
Offline oh_chesteroni
« Reply #235 on: Tue, 08 January 2019, 17:11:12 »
MX and Alps? Oh no
Hotswap? Oh no
The fear and sadness in this post is palpable.
« Reply #236 on: Tue, 08 January 2019, 17:12:52 »
Offline eagleheardt
« Reply #237 on: Tue, 08 January 2019, 17:35:47 »
I would LOVE a leaf 60, or orange 60, or any of these REALLY awesome 60% styles!!!
real question: Are you also going to look into a "Leaf 24" a leaf on a  10 key, high profile, would be super hot!!
Offline fireworm
« Reply #238 on: Tue, 08 January 2019, 17:41:54 »
BTW, as some guys requested in the Leaf 80 thread, there will also be a matching numpad available
Offline senter
« Reply #239 on: Tue, 08 January 2019, 19:32:00 »
Man, your reply scares me as well. I didn't know that happens on PC cases. Is that a common issue?
There are no stripped threads or loose screws at least on the three protos I have.
I've been using acrylic sandwich cases for many years and I never had or even heard any this kind of issues.
Polycarbonate is known to have greater strength than acrylic.
Offline dantambok
« Reply #240 on: Tue, 08 January 2019, 19:47:58 »
Stripped threads happen when someone over tightens a screw right? (Or it cracks)
Stuff  I have
100+ GMK sets
Offline ossetepo
« Reply #241 on: Tue, 08 January 2019, 20:11:30 »
PC is much tougher, PMMA is usually stronger, although their strengths are very comparable.  PC is also quite a bit softer than PMMA, depending on grade.
My guess is most of the stripped threads on PC cases are from cross threading with metal screws.  I really wish more PC case makers would use threaded inserts instead of tapping the PC itself, but this doesn't seem to be taking off.
Softer plastic screws are always a possibility - I've got PTFE screws at work that will deform long before PC will.  I've been meaning to borrow some and try them out on my PC Singa.
« Last Edit: Tue, 08 January 2019, 20:39:11 by ossetepo »
Offline senter
« Reply #242 on: Tue, 08 January 2019, 20:27:28 »
PC is much tougher, PMMA is usually stronger, although their strengths are very comparable.  PC is also quite a bit softer than PMMA.
Acrylic is more common than either PC or PMMA. Acrylic is also softer than PC. I never heard stripped thread issues even for acrylic cases. Maybe I'm ignorant but I spent a lot of time on rmk/gh/discord.
Before someone who really had the issues show up, the stripped thread issues are just suspicions. I really doubt it.
Plastic screw is a great idea, even not for solving the possible issues. I'll get some for testing later.
Offline ArchDill
« Reply #243 on: Tue, 08 January 2019, 20:30:47 »
I think most PC owners would know to be careful with it. I know I would tighten slightly under hand tight.
Offline senter
« Reply #244 on: Tue, 08 January 2019, 20:37:20 »
Some more info has been posted in OP.
The right side is the E-red I was referring to.
« Reply #245 on: Tue, 08 January 2019, 20:46:27 »
Shipping information?
Offline Wongstongs
« Reply #246 on: Tue, 08 January 2019, 20:48:11 »
Is there any plans to do a 65%? Or any other form factors for the leaf? Thanks
Offline Vigrith
« Reply #247 on: Tue, 08 January 2019, 20:48:38 »
I think it's really cool all the experimentation you're doing with colours - especially the fact you'll be offering rose gold and silver brass as well as the standard gold, I'd be extremely curious to see what the finish on those would look like as well as the black polycarb.
Great job on the prices too, I'm sure many of us appreciate your thought to keep the boards as affordable as possible - would the kit prices mentioned in the OP edit be inclusive of brass weight/plate, or will those be purchased separately like with the Leaf 80? Either way, incredibly well priced.
Really looking forward to the GB opening up!
Not Senter but I believe most of his designs are ran through ZFrontier (at least the Time TKL which I own as well as their recent Leaf 80) - I can't recall what exact method of shipping they use but the costs were actually included in the price for the Time, not sure how it was handled for the Leaf 80 but ZF's options tend to be very affordable (even internationally) when the tag is not inclusive of it.
« Last Edit: Tue, 08 January 2019, 20:50:45 by Vigrith »
Offline meiosis
  • Time
« Reply #248 on: Tue, 08 January 2019, 20:48:47 »
don't take away camo :(
Keyboards:
Aripeko TKL
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #249 on: Tue, 08 January 2019, 20:52:12 »
Nice, all in for the yellow! ...or the e-red - do you have better pictures of the red? And oh, I thought there was a numpad being mooted at some point?
« Last Edit: Tue, 08 January 2019, 23:03:32 by slxdegrees »
