Author Topic: [IC] Fox Lab - Leaf 60 (GB start)  (Read 93257 times)
Offline juaninamilli
Re: [IC] Fox Lab - Leaf 60
« Reply #350 on: Mon, 14 January 2019, 11:08:48 »
Yes
Have the plate materials been determined?
Offline laserbeamspewpew
« Reply #351 on: Mon, 14 January 2019, 11:14:30 »
« Reply #352 on: Mon, 14 January 2019, 11:16:38 »
Yes
And they are?
It's literally where you should look if you're wondering those sorts of things.
« Reply #353 on: Mon, 14 January 2019, 11:21:15 »
Yes
And they are?
If you're referring to the original post, there is no mention of plate materials, only layouts. I've seen brass, PC, and aluminum mentioned in throughout the course of the thread, but no confirmation.
« Reply #354 on: Mon, 14 January 2019, 11:22:17 »
There's an update on the OP from 1/8
Yes
And they are?
Offline reidd
« Reply #355 on: Mon, 14 January 2019, 11:25:12 »
Can anyone point to me some sample photos of E-Red?
« Reply #356 on: Mon, 14 January 2019, 11:26:55 »
Yes
And they are?
Again, no specific mention of plate materials, only layouts.
« Reply #357 on: Mon, 14 January 2019, 11:38:10 »
Son of a mother. Sorry... I misread... How very ironically stupid of me...
Yes
And they are?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #358 on: Mon, 14 January 2019, 12:46:59 »
Not sure if this has been addressed, but would it be possible for the black pc version be more translucent that opaque?
i belive thats just the nature of the material but not 100% sure
It would be really cool to have colored frosted polycarbonate.  Not necessarily in this keyboard, just in general.
Offline FunTyme
  • Formerly known as Edrylle
« Reply #359 on: Mon, 14 January 2019, 12:53:25 »
This is definitely my next board. I cant wait for GB to arrive
hbcp
Offline LuiKang
« Reply #360 on: Mon, 14 January 2019, 15:01:50 »
More suggestions on other aspects (colors, finishes, angle) are much more needed next.
Would love this board to have a 8 or 9 degrees angle for better typing experience (compared to lower angle).
Offline azharkh
« Reply #361 on: Mon, 14 January 2019, 19:25:04 »
would love to see different colours of translucent/transparent polycarbonate, akin to gameboy colour/n64 transparent colours (see attached photo for example). as for angle, 6° and under is my preference but I can deal with 7°.
Offline senter
« Reply #362 on: Mon, 14 January 2019, 20:28:20 »
Any pictures of the prototype, senter?
Clear PC, black PC, purple, and E-white.
I made an opaque white one but it was warped. It won't be available in this GB.
For e-black and yellow anodizing, you can check pics of Leaf 80.
I didn't make a prototype for e-red. It's a new color. The finish is the same with e-white, which is matte.
Here's a photo of the color:
Offline senter
« Reply #363 on: Mon, 14 January 2019, 20:29:56 »
Sure.
Basically, all the case materials are available including brass, aluminum, and PC.
Offline bengine
« Reply #364 on: Mon, 14 January 2019, 20:40:37 »
Hi Senter, are all the e-coating in a matte finish or non-matte finish?
Offline mnpq.raven
« Reply #365 on: Mon, 14 January 2019, 20:47:17 »
From the look of the prototypes, is it safe to assume that when we get aluminum plates it will also be anodized with the same finish as the case ?
Sent from my SM-G950F using Tapatalk
Offline bthezebra
« Reply #366 on: Mon, 14 January 2019, 21:14:37 »
A polycarbonate half plate would be interesting for maximum flex.
Offline Albatross
« Reply #367 on: Mon, 14 January 2019, 22:08:18 »
Nice to see PC plates will be available Can't wait for GB!
Offline blizzara01
« Reply #368 on: Tue, 15 January 2019, 03:40:17 »
Not sure but why it is the weight in the PC clear is more like shiny than others?
Offline dantambok
« Reply #369 on: Tue, 15 January 2019, 05:25:16 »
it might have been finished in PVD
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline TheArcticFox_27
« Reply #370 on: Tue, 15 January 2019, 16:08:31 »
Only 2 anodizing colors?
Offline pixelpusher
« Reply #371 on: Tue, 15 January 2019, 16:32:13 »
Has anyone seen the Alps plate?  Is it straight up Alps stabilizers,  Alps stabs + Cherry PCB on space bar (tai hao style), or perhaps SP style (All cherry stabs)?  An alps polycarb build would probably be the best feeling custom alps board you could make.  I find Alps to suffer from dampening and rigidity of stiff plates or tray mounted cases.  This is a really cool board.
Offline fireworm
« Reply #372 on: Tue, 15 January 2019, 17:22:14 »
I wish I did; been pestering him a lot about the Alps stuff.  I think it's all Alps stabilizers.  I saw a post on r/mm with an Alps Leaf 80.
I specifically asked if he could post real images of the plates, since I wanted an Alps Split Space plate...  (I'm such a snowflake,  :p )
Offline senter
« Reply #373 on: Wed, 16 January 2019, 10:37:16 »
All e-coating colors are the matte finish.
Offline senter
« Reply #374 on: Wed, 16 January 2019, 10:38:01 »
Yes.
Offline senter
« Reply #375 on: Wed, 16 January 2019, 10:38:38 »
This
Offline senter
« Reply #376 on: Wed, 16 January 2019, 10:42:27 »
ALPS stabs only.
Here are the ALPS plate layout and the capslock support.
Offline eagleheardt
« Reply #377 on: Wed, 16 January 2019, 11:17:16 »
BTW, as some guys requested in the Leaf 80 thread, there will also be a matching numpad available
how many keys? 24 please!!
Offline ggZyg
« Reply #378 on: Wed, 16 January 2019, 13:28:25 »
Would love to see a dark maroon case color
« Reply #379 on: Wed, 16 January 2019, 14:01:25 »
Is there such thing as E-purple?
Offline senter
« Reply #380 on: Wed, 16 January 2019, 14:23:47 »
The design of the numpad is finished but we decide not to run it with Leaf 60.
Too many options have been added to Leaf 60. It's safer to run Leaf 60 only this time.
Offline senter
« Reply #381 on: Wed, 16 January 2019, 14:26:13 »
Yes, e-coating have purple color but not with matte finish.
The color options for Leaf 60 have been decided and they are final.
« Reply #382 on: Wed, 16 January 2019, 14:28:37 »
Ahhh I was hoping E-Purple would have matte finish, just curious if it existed, thanks for the response
Offline senter
« Reply #383 on: Wed, 16 January 2019, 14:38:30 »
E-purple can have matte finish. It's not readily available in the factory tho. It's very expensive to make it available.
Normally we cooperate with the factory and use the available colors.
Offline fireworm
« Reply #384 on: Wed, 16 January 2019, 15:51:48 »
ALPS stabs only.
Will the entire PCB have MX/Alps solder points for all switches, even though the plate will be ANSI WKL?
« Last Edit: Wed, 16 January 2019, 18:32:33 by fireworm »
Offline eagleheardt
« Reply #385 on: Wed, 16 January 2019, 18:08:21 »
If it doesn't run together, that's fine! But if it's been finalized, what's it like? Amount of keys? I'll still buy the 60, but I also really want the numpad friend!!!
Offline -musubi
  • Spam rice 'n eggs
« Reply #386 on: Wed, 16 January 2019, 19:28:51 »
Any estimated timeline on when orders will start? I'm definitely interested in a polycarbonate one and don't want to miss out :)
Offline senter
« Reply #387 on: Wed, 16 January 2019, 19:42:19 »
Not all the switches. Only this layout is supported for ALPS:
https://i.imgur.com/XqPIyKT.jpg
Offline senter
« Reply #388 on: Wed, 16 January 2019, 19:44:52 »
It has 6 rows but only one key on the top row. I may make some changes as there's plenty of time
Offline senter
« Reply #389 on: Wed, 16 January 2019, 19:46:39 »
I've submitted the GB post.
will lock this post once GB post gets approved.
Offline AlcoholEnthusiast
« Reply #390 on: Wed, 16 January 2019, 19:52:38 »
Will solid brass be FCFS? Are there any other limits on total orders?
Offline NRbigfoot
« Reply #391 on: Wed, 16 January 2019, 19:57:40 »
Similar layout to the orange pad then?
HBCP | FLX Virgo | aanzee | Mira SE | Leaf 80 | HHKB pro 1 | qxp | Rukia | IDB60 | equinox | No1Rev1 | Whale | Montage | 268.2 | Anniversary Whale | Jer80 | Evolv
Offline ptiede
« Reply #392 on: Wed, 16 January 2019, 20:03:52 »
YAAAAAASSSSSS
Offline senter
« Reply #393 on: Wed, 16 January 2019, 20:19:40 »
