Author Topic: [IC] Fox Lab - Leaf 60 (GB start)  (Read 93254 times)
Offline senter
Re: [IC] Fox Lab - Leaf 60
« Reply #150 on: Thu, 27 December 2018, 13:42:40 »
Have you decided what rubber type you're going to be using?  Soft? Hard?
We are testing different types.
Offline senter
« Reply #151 on: Thu, 27 December 2018, 13:47:55 »
PCB relief cuts primarily come into their own with a half, or indeed no plate, the addition of a full plate largely (not entirely) neuters them so I'd agree generally.
Source: GSKT-00
That makes much more sense. The relief cuts could also be interesting when the kit is PCB top mount.
I was also thinking about 1.5mm plate only around switches and 0.8/1mm everywhere else. That's another story tho.
Offline ChrisSwires
« Reply #152 on: Thu, 27 December 2018, 13:50:58 »
Source: GSKT-00
Now. A variable depth plate. That gets me all kinds of intrigued.
Sent from my Pixel 3 using Tapatalk
Offline DasGnome
« Reply #153 on: Thu, 27 December 2018, 14:22:01 »
Source: GSKT-00
PCB top mount would be tempting....
Offline juaninamilli
« Reply #154 on: Thu, 27 December 2018, 14:42:21 »
PCB top mount? I'm having a hard time picturing it. I will say that I would prefer top mount plate.
Offline clasicks
  • Formerly KeyboardUser4
« Reply #155 on: Thu, 27 December 2018, 15:06:53 »
wat, this IC is for sandwich mount pseudo gasket, y u talking about top mounts in chat
Offline weaston
« Reply #156 on: Thu, 27 December 2018, 21:53:28 »
🤔 I doubt the effect of the relief cuts tbh. I don't own a 00 so cannot verify it by myself.
There is very little information about it. I incline to believe it's not a good feature that has been generally accepted.
In this case, I would not consider this feature because otherwise it's more like a direct copy without thinking.
Please do not copy what we did without an understanding of why it is there and how it influences the board as a whole.  The 00 is not the end all be all gasket board and there are many things that need changing and refinement.  We did things for very specific reasons and have a lot to learn, so copying bits and pieces of the 00 indiscriminately will only lead to problems in your own design because the two boards are inherently different.
DK Saver | Kingsaver | OTD 360 Corsa | OTD 456GT | OTD Cheat | KMAC 1.3 | KMAC 1.2 | KMAC Happy | KMAC Pad | KMAC Mini (Revo) | Singa | HHKB Pro 1 | GSKT-00 | IBM 5251 | IBM Model F XT | IBM Model M | Dolch PAC | Kinesis Advantage
Offline mdlt97
  • This **** is still better than Keebtalk
« Reply #157 on: Thu, 27 December 2018, 23:09:10 »
Why are you on such a mission to dismiss/discredit everything gasket related about this board, you didn't invent gasket, you made a board for people who couldn't afford or get a 356 mini, that is all you did, not sure why you talk about it like its the second coming of Jesus himself, just relax and let someone run a Gb how they please and let them do what they want, as it is THEIR board
TX60 | Duck TC-V3 | Duck Eagle V2 1/1 Bottom | Zephyr r2 | Duck Sidewinder | Mech27v2 | TX75 | LZ CLS | Duck Viper v2 | Orion v3 | HHKB pro 1 | TGR 910 | Omega60
Offline senter
« Reply #158 on: Fri, 28 December 2018, 09:00:30 »
That's exactly what I was saying. Someone asked me to copy a feature of 00. I said no.
Offline weaston
« Reply #159 on: Fri, 28 December 2018, 09:13:13 »
That was my understanding too, wasn't meaning it in any bad way. I like your design and wanted to see it explored.
Offline clasicks
« Reply #160 on: Fri, 28 December 2018, 09:39:32 »
its almost like you didn't read anything that weaston said... take your predisposed salt somewhere else
Offline taropaste
« Reply #161 on: Fri, 28 December 2018, 11:06:42 »
This board looks great and I'm looking forward to trying your implementation of a gasket sandwich mount. I'm also VERY excited about a polycarb wkl version. Please please pretty please make that available for the group buy :D. Thanks!
« Last Edit: Fri, 28 December 2018, 11:08:44 by taropaste »
Offline dondongler
  • Gotta Light?
« Reply #162 on: Fri, 28 December 2018, 11:10:10 »
Definitely interested in polycarb as well
Offline Rumai
« Reply #163 on: Fri, 28 December 2018, 12:34:59 »
BTW, as some guys requested in the Leaf 80 thread, there will also be a matching numpad available
YES
YES
Offline HardcoreDesk
« Reply #164 on: Fri, 28 December 2018, 21:46:35 »
this board makes me say yes
Offline finalarcadia
« Reply #165 on: Fri, 28 December 2018, 22:05:43 »
Matching numpad with same rows as leaf 60? That'd be nicer
Offline azharkh
« Reply #166 on: Sat, 29 December 2018, 03:28:45 »
if you decide to go for a proprietary PCB can it have underglow LEDs or at least have pads on the bottom side of the PCB so SMD LEDs can be soldered on by the user if they choose?
Offline metalliccharles
« Reply #167 on: Sat, 29 December 2018, 11:08:03 »
I hope the price is good because I have to get this! :-\  PC with the brass plate looks so gooood. :cool:
Offline nasp
« Reply #168 on: Sat, 29 December 2018, 12:24:24 »
Is it possible to have a proprietary PCB but also keep the USB C connector on the left side? That way, one could still put in a DZ60 with USB C? I think it's a good compromise and will allow folks some other options for PCBs
Offline fireworm
« Reply #169 on: Mon, 31 December 2018, 23:23:00 »
Is there a picture of all supported layouts for mx? Layouts for alps?
If you could do split space alps, omg. I'd buy like 10!
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #170 on: Tue, 01 January 2019, 05:01:40 »
I think the purpose of the proprietary PCB is so he can have the center port...
Offline Vigrith
« Reply #171 on: Tue, 01 January 2019, 13:03:23 »
I might've missed it but do you have a tentative ETA for the GB for this to open up, Senter?
Offline ArchDill
« Reply #172 on: Tue, 01 January 2019, 14:36:52 »
Simply put, this is an IC for 60% version of Leaf 80.
This IC is not for checking interests because we will run it for sure.
The purpose of this IC is for collecting suggestions/opinions on the current design and future available options.
Some potential new features:
  • New plate mounting method. We've been using top mount for quite a long time. Now we're trying to figure out how to play with gaskets. Not sure if the current design can be called gasket mount or not.
  • Anodizing: new regular colors, gradient anodizing, camo ano, hard ano
  • E-coating: new colors, non matte finish (the original e-white and e-black are all matte finish)
  • PVD brass case: It was a pain to deal with PVD because the quality is hard to control. Exclusive found a reliable factory that can do PVD in very high quality. It might be worth trying. Really appreciate his help.
  • PC case: Anyone interested in opaque PC cases? I'm not sure about the aesthetic aspect but the PC cases sound different from metal cases.
The current design is to attach 4 long strips of self-adhesive gaskets on both the top case and the bottom case.
The gaskets have screw holes on them. They will be compressed a little bit when the screws are tightened.
The front and rear sides of the plate will be sandwich mounted in the middle.
The PC leaf is very tempting. Will there be an hhkb layout plate? It triggers me when you can see the plate under the PC and it has an opening for switches.
Offline AlcoholEnthusiast
« Reply #173 on: Tue, 01 January 2019, 16:24:17 »
Is there an estimate on price yet?
Offline DocNoc
« Reply #174 on: Wed, 02 January 2019, 00:38:32 »
The pcb will allow for standard Cherry/GMK style stabs correct? Only asking because I'm ignorant and don't know if the fact that the PCB will be Alps compatible will change anything else about the PCB design.
Offline DasGnome
« Reply #175 on: Wed, 02 January 2019, 12:23:28 »
Any plans for a PC plate to go with the PC case? :)
Offline senter
« Reply #176 on: Wed, 02 January 2019, 16:35:48 »
1. None hot-swappable + MX layout:
2. None hot-swappable + ALPS layout:
3. Hot-swappable + MX layout:
BTW, what keycaps do you want to use on split space alps? I didn't know that's a thing
Offline senter
« Reply #177 on: Wed, 02 January 2019, 16:42:46 »
Hi Vigrith, it can happen as early as in Jan. I have made several prototypes. One opaque white PC case is bad. All the others look great to me. Everything should be settled soon.
The only thing concerns me rn is the CNY. The long holiday of CNY can lead to serious delays.
Offline senter
« Reply #178 on: Wed, 02 January 2019, 16:43:29 »
Yes
Offline senter
« Reply #179 on: Wed, 02 January 2019, 16:43:58 »
Offline senter
« Reply #180 on: Wed, 02 January 2019, 16:45:10 »
It will support PCB mount Cherry/GMK stabs.
Offline DJSwayde
« Reply #181 on: Wed, 02 January 2019, 16:46:35 »
Has it been decided whether a universal or proprietary PCB will be used?
Sent from my SM-G920T using Tapatalk
60%: CannonKeys Bakeneko60
BUILD 1: Black | FR4 plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
BUILD 2: Black | 1upkeyboards π60 (pi60) PCB | 1upkeyboards FR4 plate | Akko Rosewoods | HammerWorks CRP R6 Egyptian Alphas kit & CRP R7 kits (40%, 60%, Spacebars, Stepped Modifiers) keycaps
 | GEONWORKS Frog Mini
Silver | HHKB | 4pplet Steezy60 (Alps) PCB | Custom SS plate | Alps SKCL Yellows | Canon S-14 & S-16S keycaps
| GEONWORKS LAUNCHER60
Silver | Custom PCB | Custom SS plate | Alps SKCL Creams | C.Itoh CIT224F & IBM 5140 keycaps
| LSJ Ares
Silver | Custom PCB | Custom SS plate | Alps SKCL Browns & SKCL Amber | IBM Multistation 5556-CC1 (TW) & P70 (ANSI-US, 06-89) keycaps
 | LZ CLS h
Silver | Custom PCB | Custom SS plate | Alps SKCM Creams | MET Micro Officer 6000 (R315-00) & Zenith Data Systems TurbosPORT 386 keycaps
| MONOKEI Kei R1
Standard Red | Aluminum plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G81-1291SAW & G81-3090SAQ (Schneider) keycaps
| SINGAKBD Unikorn R1
Black | Black aluminum plate | Cherry Retooled Blacks (TX 60g springs) | G80-3485LWNUS (Das Keyboard II) keycaps
| Wangus x KEZEWA Snake60 R2
Silver (re-anodized hot pink) | WKL | Custom PCB | Custom SS plate | NMB "Space Invader" (White one-eye linear [fourth generation]) | NMB RT-101 (NCD) keycaps
 | Weaston GSKT-00-Z
Silver | AEK HHKB | Aluminum plate | Alps SKCL Greens | Apple Extended Keyboard II (M3501, Taiwanese) & Standard Keyboard (M0116, US) keycaps
Pad: KBDFans KBDPAD MKII
Black | FR4 plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G80-3485LWNUS (Das Keyboard II) keycaps
| KBDMania KMAC Pad
Titanium grey | Aluminum plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G81-3090SAQ (Schneider) keycaps
| Leopold FC 210TP
White | Custom PCB | Custom SS plate | Alps SKCL Compact Greens & Alps SKCL Browns | C.Itoh CIT224F keycaps
| Momokai Aurora
Cherry Vintage Blacks (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
Topre: PFU Ltd. HHKB Pro 1 (PD-KB300BN)
hasu Alt USB controller | Topre Realforce 91UDK-G (NG02B0) & Realforce 103UB (SE42B0) keycaps
| PFU Ltd. HHKB Pro 2 (PD-KB400B)
hasu Alt Bluetooth controller | Purple sliders | 35g domes | Stock & Topre Realforce Taiwanese kit (dark gray) keycaps
| PFU Ltd. HHKB Pro 2 Type-S (PD-KB400WS)
4pplet SHKB Lite controller | 25g domes | Topre Realforce 87UW55 (SE08T0), Realforce 91UW (NE0100), Realforce Taiwanese kit (white) keycaps
| Topre Realforce 23U (WC0100)
Cipulot EC23U PCB | Purple sliders | SS plate (modified to allow for 24U) | 25g domes | JUKI Celavi keycaps
 | Topre Realforce 87UW (SE08T0)
Purple sliders | 30g domes | Sony BKE-9400A, MKS-8050, PVE-500, stock keycaps
| Topre Realforce 91 (NE0100)
Cipulot RF R1 8-9Xu PCB | 30g domes | JUKI Celavi & Topre Realforce 108UG-HiPro (YK0100) keycaps
Other: Apple Desktop Bus Keyboard (C658-4081) (CA)
Alps SKCM Oranges & SKCL Lock Cream
| Apple M0110A (US)
Beige | Vortex ViBE (US) (case installed inside) | Custom PCB | Custom SS plate | Alps SKCM Blues | Hewlett Packard HP Portable Vectra CS (US) & R/332 Instrument Controller (US) keycaps
| KUL ES-87
Black | Keygeek Su Color V2s (45g) | MW Heresy (with Gluttony & Envy kits) keycaps
| Zuoya HE30
Black | Hotswap: Keytok Novas / Wooting Lekker Tikken Mediums | Ranked POM keycaps
Collection
Offline senter
« Reply #182 on: Wed, 02 January 2019, 16:46:56 »
I'll decide after testing the prototypes. I wish that can be available.
Offline forevermadrigal
« Reply #183 on: Wed, 02 January 2019, 16:47:18 »
Any more info on the gaskets?
Offline o3okevin
« Reply #184 on: Wed, 02 January 2019, 17:29:54 »
Probably in but are there any chances that other form factors would be made? Like 65%, 75%, even fullsize?
Offline fireworm
« Reply #185 on: Wed, 02 January 2019, 17:40:07 »
Awesome, I'd be using Nexus sliders with some SA caps, so cherry stabs work. (but I have adapters for alps stabs too).
Layout (for me), would be: split backspace, split right shift.
Splitting a 6.25u Spacebar into 2.25, 1.25, 2.75. (followed by four 1.25)
Or splitting a 7u into 2.25, 1, 2.75, 1.
...Not sure how possible this is.
Offline ArchDill
« Reply #186 on: Wed, 02 January 2019, 17:49:15 »
Yes
Sweet! I am excited about this! I have been wanting to try a PC build.
Offline Vigrith
« Reply #187 on: Wed, 02 January 2019, 20:00:06 »
Hey Senter, alright that sounds good - thank you for sharing, I appreciate the heads up and yea CNY can be quite the obstacle as has been proven many times.
I'm very much looking forward to it, especially given the fact you confirmed there'll be a dedicated HHKB plate - that'll look great with the PC case, PC case + brass is beautiful.
Offline dantambok
« Reply #188 on: Wed, 02 January 2019, 20:26:14 »
Looks like my dream of a WKL PC 60% will come true  :))
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline temp0321
« Reply #189 on: Wed, 02 January 2019, 21:03:46 »
Oh, there will be a hotswap pcb option? Is it possible to have 2u backspace for it?
Offline ejewell89
  • 4ever Smol
« Reply #190 on: Wed, 02 January 2019, 21:24:47 »
Will it support both split spacebar layouts?
225 125 275
And the inverse
275 125 225
Offline trg1234
« Reply #191 on: Wed, 02 January 2019, 22:02:47 »
From reading I think there's more people who would benefit from the universal pcb option more than the prorpietary one personally.
Offline slxdegrees
  • Nerds With Keebs
« Reply #192 on: Wed, 02 January 2019, 22:05:13 »
Better pray the pcb doesn't fail then
« Last Edit: Wed, 02 January 2019, 22:07:01 by slxdegrees »
Offline befbef
« Reply #193 on: Wed, 02 January 2019, 22:34:25 »
Very interested. Hope it's gonna be universal pcb!
Offline spyruf
« Reply #194 on: Wed, 02 January 2019, 23:55:33 »
Depending on price I am quite interested in the hotswap hhkb layout.
« Reply #195 on: Thu, 03 January 2019, 02:25:05 »
I feel like I'm on an island with this one, but if the proprietary PCB lets us get a very tight port I think it's the right move.
Unless the board was based around DZ60 and the tight port was modeled around an already established and easy to get PCB (which I think is a pretty good idea)
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #196 on: Thu, 03 January 2019, 04:54:26 »
If the PCB needs to be proprietary, why not open-source it after the GB? At least then someone can get a small batch made in the future.
Offline LuiKang
« Reply #197 on: Thu, 03 January 2019, 07:18:38 »
HHKB layout + splitted spacebar = I'm in.
HHKB layout + splitted spacebar + side/underglow = I'll reserve two.
« Reply #198 on: Thu, 03 January 2019, 08:19:26 »
Not that it'll affect much, but why split l.shift? In no way am I suggesting iso, but don't those two usually go together?
Offline spyruf
« Reply #199 on: Thu, 03 January 2019, 09:51:46 »
Another thing that would be interesting is if the weight is the same as the leaf 80. That way they are replaceable / swappable.
