Author Topic: [IC] Fox Lab - Leaf 60 (GB start)  (Read 93254 times)
Offline o3okevin
Re: [IC] Fox Lab - Leaf 60
« Reply #50 on: Sat, 22 December 2018, 17:45:54 »
was blown away with my fox leaf 80 so in for this one even though I don't like 60%
How I feel exactly, definitely down for a leaf 60 :)
Offline senter
« Reply #51 on: Sat, 22 December 2018, 17:55:47 »
E6 had 19mm bottom row spacing and 00 had the gasket in between pcb and plate, so they needed custom pcbs. The mounting on this design doesnt interfere with standard 60% pcbs, so you could just accomodate for those instead.
Unless there is a hindrance to topside usb that could happen.
Just my 2cents.
GSKT-00 and E6-V2 are both great boards and both use proprietary PCBs.
We used our own pcb for the 00 for very specific fitment reasons.  Those reasons do not seem to apply in this case because of how the "gasketing" is being performed.
Just for clarification.
Thanks for clarifying. I said the reasons why I want to use a proprietary PCB. Mentioning 00 and E6 was just for providing evidence that 60% proprietary PCBs are not that rare. I believe E6 and 00 both have good reasons as well.
There are always tradeoffs. I can't say which option is definitely better than another. I'm glad people brought it up and discuss it in details. I'll make decisions based on the discussion here.
Offline senter
« Reply #52 on: Sat, 22 December 2018, 18:03:19 »
I love everything about this. When are you looking at running it?
I don't care much about the timing so the GB will be launched when everything is settled.
The overall design is finished. Next, I'll make some small changed on the design and make several prototypes.
It can be very fast if I'm satisfied with the result.
Offline azharkh
« Reply #53 on: Sat, 22 December 2018, 18:07:14 »
this would probably add a bit to the cost but have you thought of maybe having a universal cutout but also having the option of using an adapter of sorts that is a perfect fit for a proprietary PCB? that way you can have the perfect fit that you want while giving people the option of universal compatibility
Offline senter
« Reply #54 on: Sat, 22 December 2018, 18:07:37 »
looks really good. i don't mind the proprietary pcb as long as i can have hhkb with split space bar. it would be really awesome if this turns out extra heavy, i'm talking like 2kg+
like full brass heavy?
Offline senter
« Reply #55 on: Sat, 22 December 2018, 18:10:54 »
universal cutout is large and ugly. That's the main reason I don't like it. Keeping the universal cutout then there's no reason I want to make a proprietary PCB.
Offline azharkh
« Reply #56 on: Sat, 22 December 2018, 18:13:21 »
I meant like you could have an adapter that would fit into the universal hole so it would no longer be universal allowing a proprietary PCB to fit perfectly in it while giving people the option to remove the adapter, making the hole universal again.
not sure if that made sense but hopefully you get my idea
that being said I do prefer tight cutouts
« Last Edit: Sat, 22 December 2018, 18:36:59 by azharkh »
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #57 on: Sat, 22 December 2018, 18:36:09 »
I’d much prefer tight USB cutout, but share the same concern with others about the hassle of replacing proprietary PCB if need be.
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline senter
« Reply #58 on: Sat, 22 December 2018, 18:46:50 »
Oh, I see what you mean. Yeah, that's a solution. However, the border of the current design is not that large that put an adapter there. Enlarging the border and using an adapter is too much just for making a tight cutout imo.
Offline airlangga07
« Reply #59 on: Sat, 22 December 2018, 18:50:55 »
Id definitely in! maybe for PC one...
Offline azharkh
« Reply #60 on: Sat, 22 December 2018, 18:53:57 »
it's definitely not ideal and I too would prefer to have a non universal cutout but based on the responses it's starting to seem like a necessary compromise
edit: I had an another idea: instead of using an adapter, perhaps it could also work as a badge/accent of sorts. like you'd slot it into place (think GBA cartridge style-ish) and it'd look like an accent or badge and you'd have one that had a universal hole and one that had a proprietary hole. that wouldn't require enlarging the border and it would add a design element. just an idea.
« Last Edit: Sat, 22 December 2018, 18:59:21 by azharkh »
Offline vtachkov
« Reply #61 on: Sat, 22 December 2018, 19:14:44 »
I might be in for a PC one, even though I'm not that big of a fan of 60%. Please tell me that after this is going to be the leaf 65% :)
Offline Albatross
« Reply #62 on: Sat, 22 December 2018, 19:29:41 »
Interested in a PC HHKB variant :)
Will there also be PC plates available?
Offline weaston
« Reply #63 on: Sat, 22 December 2018, 20:05:10 »
Yes agreed I can't say either.  Regardless this looks really awesome and the Leaf quality impressed the absolute hell out of me, so more power to you guys in whatever way you choose.  I hope it turns out great.  :)
DK Saver | Kingsaver | OTD 360 Corsa | OTD 456GT | OTD Cheat | KMAC 1.3 | KMAC 1.2 | KMAC Happy | KMAC Pad | KMAC Mini (Revo) | Singa | HHKB Pro 1 | GSKT-00 | IBM 5251 | IBM Model F XT | IBM Model M | Dolch PAC | Kinesis Advantage
Offline DJSwayde
« Reply #64 on: Sat, 22 December 2018, 20:12:06 »
Would you offer fixed ISO plate?
60%: CannonKeys Bakeneko60
BUILD 1: Black | FR4 plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
BUILD 2: Black | 1upkeyboards π60 (pi60) PCB | 1upkeyboards FR4 plate | Akko Rosewoods | HammerWorks CRP R6 Egyptian Alphas kit & CRP R7 kits (40%, 60%, Spacebars, Stepped Modifiers) keycaps
 | GEONWORKS Frog Mini
Silver | HHKB | 4pplet Steezy60 (Alps) PCB | Custom SS plate | Alps SKCL Yellows | Canon S-14 & S-16S keycaps
| GEONWORKS LAUNCHER60
Silver | Custom PCB | Custom SS plate | Alps SKCL Creams | C.Itoh CIT224F & IBM 5140 keycaps
| LSJ Ares
Silver | Custom PCB | Custom SS plate | Alps SKCL Browns & SKCL Amber | IBM Multistation 5556-CC1 (TW) & P70 (ANSI-US, 06-89) keycaps
 | LZ CLS h
Silver | Custom PCB | Custom SS plate | Alps SKCM Creams | MET Micro Officer 6000 (R315-00) & Zenith Data Systems TurbosPORT 386 keycaps
| MONOKEI Kei R1
Standard Red | Aluminum plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G81-1291SAW & G81-3090SAQ (Schneider) keycaps
| SINGAKBD Unikorn R1
Black | Black aluminum plate | Cherry Retooled Blacks (TX 60g springs) | G80-3485LWNUS (Das Keyboard II) keycaps
| Wangus x KEZEWA Snake60 R2
Silver (re-anodized hot pink) | WKL | Custom PCB | Custom SS plate | NMB "Space Invader" (White one-eye linear [fourth generation]) | NMB RT-101 (NCD) keycaps
 | Weaston GSKT-00-Z
Silver | AEK HHKB | Aluminum plate | Alps SKCL Greens | Apple Extended Keyboard II (M3501, Taiwanese) & Standard Keyboard (M0116, US) keycaps
Pad: KBDFans KBDPAD MKII
Black | FR4 plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G80-3485LWNUS (Das Keyboard II) keycaps
| KBDMania KMAC Pad
Titanium grey | Aluminum plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G81-3090SAQ (Schneider) keycaps
| Leopold FC 210TP
White | Custom PCB | Custom SS plate | Alps SKCL Compact Greens & Alps SKCL Browns | C.Itoh CIT224F keycaps
| Momokai Aurora
Cherry Vintage Blacks (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
Topre: PFU Ltd. HHKB Pro 1 (PD-KB300BN)
hasu Alt USB controller | Topre Realforce 91UDK-G (NG02B0) & Realforce 103UB (SE42B0) keycaps
| PFU Ltd. HHKB Pro 2 (PD-KB400B)
hasu Alt Bluetooth controller | Purple sliders | 35g domes | Stock & Topre Realforce Taiwanese kit (dark gray) keycaps
| PFU Ltd. HHKB Pro 2 Type-S (PD-KB400WS)
4pplet SHKB Lite controller | 25g domes | Topre Realforce 87UW55 (SE08T0), Realforce 91UW (NE0100), Realforce Taiwanese kit (white) keycaps
| Topre Realforce 23U (WC0100)
Cipulot EC23U PCB | Purple sliders | SS plate (modified to allow for 24U) | 25g domes | JUKI Celavi keycaps
 | Topre Realforce 87UW (SE08T0)
Purple sliders | 30g domes | Sony BKE-9400A, MKS-8050, PVE-500, stock keycaps
| Topre Realforce 91 (NE0100)
Cipulot RF R1 8-9Xu PCB | 30g domes | JUKI Celavi & Topre Realforce 108UG-HiPro (YK0100) keycaps
Other: Apple Desktop Bus Keyboard (C658-4081) (CA)
Alps SKCM Oranges & SKCL Lock Cream
| Apple M0110A (US)
Beige | Vortex ViBE (US) (case installed inside) | Custom PCB | Custom SS plate | Alps SKCM Blues | Hewlett Packard HP Portable Vectra CS (US) & R/332 Instrument Controller (US) keycaps
| KUL ES-87
Black | Keygeek Su Color V2s (45g) | MW Heresy (with Gluttony & Envy kits) keycaps
| Zuoya HE30
Black | Hotswap: Keytok Novas / Wooting Lekker Tikken Mediums | Ranked POM keycaps
Collection
Offline AlcoholEnthusiast
« Reply #65 on: Sat, 22 December 2018, 20:40:41 »
Initially I was on board with universal PCB (and still wouldn't be mad if that happened). But after someone brought up the M60 USB port and how clean it looked i think I kind of agree with proprietary PCB now if the end result is looking super clean like that one did. Kind of wanted to make this board a hotswap, but I don't mind using another board for that.
Offline Deathcaps
    • Death-caps.com
« Reply #66 on: Sat, 22 December 2018, 20:54:49 »
Yeah, i really want one of these. pls keep the hhkb/wkl option
Offline trg1234
« Reply #67 on: Sat, 22 December 2018, 21:07:58 »
Honestly it's just a tossup between aesthetics and customizability I believe at this point. I'm all for aesthetics, but I also want features that I'm not sure other people want such as hotswap and usb c compatibility.
Offline Gati
« Reply #68 on: Sat, 22 December 2018, 21:40:14 »
This is gonna sound pretty ignorant, but couldn’t it be possible to design the case around a PCB already on the market (like a DZ60)?
Offline senter
« Reply #69 on: Sat, 22 December 2018, 21:48:06 »
Only if there are enough interests. I doubt it now so no. Sorry.
Offline senter
« Reply #70 on: Sat, 22 December 2018, 21:51:30 »
I haven't thought about it tbh.
I asked the factory to source PC materials and they didn't even find clear PC materials for the case until now. They only sourced opaque materials.
PC plate + gasket sounds interesting. Let me see if it's possible.
Offline senter
« Reply #71 on: Sat, 22 December 2018, 22:07:10 »
I believe most people here are familiar with this but let me clarify it to those who don't.
Most 60% PCBs, including DZ60, have the same USB port position. It's in the middle of the ESC key and 1 key.
Many 60% cases were designed for supporting these PCBs.
However, many PCBs have different USB female port with slightly different dimensions, some use USB C ports, some even have slightly off-center positions.
As a result, in order to support all the 60% PCBs, the USB port cutout must be very large.
What you asked is to support a specific 60% PCB. What some other people asked is to support most 60% PCBs with a large cutout. What I intended to do is to make a perfect cutout like on M60-A like someone mentioned.
Offline gabetjh
« Reply #72 on: Sat, 22 December 2018, 22:09:31 »
will u plan to make it hot swappable or at least design the pcb to allow socket installation?
Offline ian13
« Reply #73 on: Sat, 22 December 2018, 22:39:41 »
That purple, though!
Offline temp0321
« Reply #74 on: Sat, 22 December 2018, 22:45:04 »
Universal pcb would be great as I'm one of the people who wants to use the hot swap pcb into this beautiful case.
Offline Gondolindrim
    • My GitHub
« Reply #75 on: Sat, 22 December 2018, 23:06:46 »
I don't particularly mind the proprietary PCB, as long as the case is tightly made to fit it -- which I think is the idea here. What I wouldn't recommend though is an ALPS compatible circuit board, because the PCB holes get too wide and you'd need too much sodder to fill them. I'd also like it to be Mini USB and not USBC as I have has problems with the latter being too delicate.
If the price is in the 250 range, count me in.
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline HardcoreDesk
« Reply #76 on: Sat, 22 December 2018, 23:34:12 »
Please stick with the proprietary PCB. Universal cutouts look ugly and, personally speaking, on a high-end board like this I'd rather have every aspect of the board be deliberate for the best looks and feel. Having to sacrifice looks to accommodate accessibility is something I don't really care for in a board, and I'm sure many others feel the same.
« Reply #77 on: Sat, 22 December 2018, 23:41:17 »
miniUSB/USBC only cutout in universal position is probably the most elegant compromise
but also, its your board, and there are plenty of good boards with their own PCBs, as was mentioned before
just depends on who your ideal buyer is for the kit
Offline meiosis
  • Time
« Reply #78 on: Sat, 22 December 2018, 23:48:33 »
I think a good option is to add usb C-> miniusb converter/adapter since they are so cheap haha. and since USB c looks nicer with smaller cut out it should be okay.
Keyboards:
Aripeko TKL
« Reply #79 on: Sat, 22 December 2018, 23:59:01 »
this is also a good idea
Offline dantambok
« Reply #80 on: Sun, 23 December 2018, 00:08:05 »
Yes definitely into this one. really interested for a polycarb and i like the idea of using a universal PCB more
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline hhkbp2
« Reply #81 on: Sun, 23 December 2018, 00:39:21 »
Gasket mount 60%. Nice.
Sure the USB port cutout is not pretty if all types of Mini-USB, USB-C universal PCBs are supported. It would be a "close" compromise if it supports one type only, for example USB-C, when tight cutout is preferred.
Take a step further, if we go to proprietary PCB, the cutout should be right in the middle for aesthetics, like M60, Viper, E6, etc.. I think it's also a good choice for a tight cutout in this case.
IMO it will go too far to have a usb cutout on the right, which looks like a bit randomly positioned in current render picture.
« Last Edit: Sun, 23 December 2018, 00:43:39 by hhkbp2 »
Offline bthezebra
« Reply #82 on: Sun, 23 December 2018, 00:57:12 »
Can't wait still gotta build leaf tkl.
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #83 on: Sun, 23 December 2018, 07:55:02 »
Will there be any proxies or will it be zfrontier only?
Offline dado brat
« Reply #84 on: Sun, 23 December 2018, 07:55:56 »
Well, I was thinking about something in the range of the M60-a with internal weight (2.2kg I think). I don't know much about PVD brass, but if you could manage to make those dank colors (like in the renders) i would be really intrigued to try full brass. Another option would be a 3-5mm brass plate as an extra or something like that
Offline trg1234
« Reply #85 on: Sun, 23 December 2018, 08:35:49 »
Will there be like a poll or something at the end to see the opinions.
Offline 1023andy
« Reply #86 on: Sun, 23 December 2018, 18:59:13 »
Is this compatible with alps switches? White leaf60 and aek keycap would look nice
Offline mnpq.raven
« Reply #87 on: Sun, 23 December 2018, 19:24:30 »
Looking forward to more info & updates of E-coating prototypes!
Offline Vigrith
« Reply #88 on: Sun, 23 December 2018, 20:11:19 »
Polycarb HHKB? Let's go.
Offline 112227
« Reply #89 on: Sun, 23 December 2018, 23:16:58 »
missed out on the leaf 80, WILL NOT miss this one. I too would love to see it in yellow.
« Reply #90 on: Mon, 24 December 2018, 00:17:10 »
Can someone eli5 what E-coating is?
Offline 112227
« Reply #91 on: Mon, 24 December 2018, 03:50:21 »
Just saw where the USB port is located.  :'(
Offline beekey
« Reply #92 on: Mon, 24 December 2018, 04:26:59 »
[double post]
« Last Edit: Mon, 24 December 2018, 05:27:45 by beekey »
Offline mnpq.raven
« Reply #93 on: Mon, 24 December 2018, 04:30:01 »
Would prefer support for standard 60%, but I see the point of going for style. Sadly, PCBs break and then you have an expensive piece of art to look at.
As long as it supports split space I would still be interested. But please provide the option to buy a replacement PCB.
What do you mean PCBs break ? They are not going to snap like toothpicks easily
Sent from my SM-G950F using Tapatalk
Offline beekey
« Reply #94 on: Mon, 24 December 2018, 05:26:31 »
Beautiful case with WKL and split space layout support.  :thumb:
Sadly, PCBs break and then it is hard to get replacements.  As I don‘t see the back of the case that often, I vote for funtionality over style. So, I would prefer standard 60% support, but as long as we can get additional PCBs I would be in.
Offline Legoo
  • Hello
« Reply #95 on: Mon, 24 December 2018, 05:27:38 »
Would probably be interested in a PC case with Alps switches, looks really nice !
E6_V2 R2 | Time80RE | OTD The Cheat | J80 | Iron180 | Solenoid MX M0110A | ACR60 | HHKB Pro 2 | Brown Alps Duck Orion v3 | TGR Alice Polycarb proto | Duck Lightpad | Orange Alps Duck Raven | TADA68 | TX75 | LZ CLS MS
Offline beekey
« Reply #96 on: Mon, 24 December 2018, 05:31:43 »
Sorry, break = die. I damaged one while switching from one case to another. Could not find the cause.
Offline senter
« Reply #97 on: Mon, 24 December 2018, 08:11:49 »
I may provide two versions of PCBs. One supports multiple layouts and without sockets. One supports a single layout and with sockets.
Offline senter
« Reply #98 on: Mon, 24 December 2018, 08:16:57 »
Is that very bad? Solders are cheap.
any evidence USB C is more delicate than Mini USB? I always thought Mini is delicate tbh
Offline Vigrith
« Reply #99 on: Mon, 24 December 2018, 08:30:16 »
Agreed, after about a year of switching between dailies using Mini and C, C feels way more robust; not to mention it's infinitely more convenient, but everyone knows that already.
