Author Topic: Metal keyboard and electric shocks. What to do?  (Read 41032 times)
Offline dream3
« on: Sat, 26 January 2019, 09:49:07 »
Hey guys,
I have a metal mechanical keyboard and often I get electric shocks when I touch it. I guess it's due to winter + heating + static right?
Well, how do I know if the problem is with the keyboard itself or something else?
My setup is the keyboard connected to a USB hub which is connected to my macbook's USB port. The HUB is powered. The macbook's charger is connected to a common power strip.
Any ideas on how to troubleshoot this?
Offline killyou
Re: Metal keyboard and electric shocks. What to do?
« Reply #1 on: Sat, 26 January 2019, 18:05:55 »
You can take it apart and check whether there are any metal elements from the PCB contacting the case.
Offline Sup
« Reply #2 on: Sat, 26 January 2019, 18:44:36 »
Put electrical tape on the mounting holes of the case and make a small hole for the screw to go in. Should stop conducting electricity.
current
Coming soon
Offline pixelpusher
« Reply #3 on: Sat, 26 January 2019, 19:06:26 »
I’ve been in many threads discussing this.  Sometimes electrical tape helps, but it’s just the nature of the game.  I have dozens of boards that I shock myself on in the winter when it’s dry.  Here’s my final solution... I keep a lightning cable attached to my computer with the end by my keyboard.  I touch the tip of it before I sit down and let it shock me.
I’ve even shocked myself on an old Chicony board from the 90s.
Think about it.  You can shock yourself on the kitchen sink.  It’s nothing to do with power.  It’s just static discharge from your body
« Reply #4 on: Sun, 27 January 2019, 03:17:01 »
If by "shock", you actually really mean tingling felt when sliding your finger across the keyboard's case then the case might be connected to the ground wire in the USB cable.
If the keyboard has a USB socket and that socket is in contact with the case, then that could be it.
« Last Edit: Sun, 27 January 2019, 03:22:12 by Findecanor »
Offline dream3
« Reply #5 on: Sun, 27 January 2019, 08:32:02 »
Im not sure I got that one. My case has a flat bottom plate that attaches to it with 4 screws through the bottom. Should I put the electrical tape outside or in between the case and the bottom plate?
I has a USB-C that could totally be in contact with the case. But those should be isolated right? Isnt that basic?
I think you are right but for some reason I got much more from the keyboard than anything else. Ill try that though, lightning cable connected via USB to the computer and the lightning end free to shock you, is that it?
No, it's a literal shock that makes noise. It has a USB-C port.
Offline abrahamstechnology
« Reply #6 on: Wed, 30 January 2019, 20:59:41 »
Sounds like the problem I've been having. Your computer isn't properly earth grounded. Make sure your laptop has a 3-prong earthed plug.
« Last Edit: Wed, 30 January 2019, 21:02:09 by abrahamstechnology »
Offline dream3
« Reply #7 on: Wed, 30 January 2019, 21:22:45 »
Apple chargers have only 2 prongs but the outlet strip that it is connected to has 3.
Offline ander
  • I type, therefore I am
« Reply #8 on: Sun, 03 February 2019, 05:37:07 »
You need an antistatic wrist strap. Computer technicians wear them to avoid damaging fragile components when they touch them.
Before you get one, though, there's something you should know: They're chick magnets. If you put on an accessory that hot, be prepared to have babes climbing in through your windows.
« Reply #9 on: Sun, 03 February 2019, 07:33:14 »
/Confirmed..
/Tp4 ordering now. !!
Offline zatera
« Reply #10 on: Wed, 18 November 2026, 14:33:49 »
A handy guide on wiring safety can be found here: https://onlinebilllesco.pk/.
