Author Topic: INSANITY  (Read 4529 times)
INSANITY
« on: Tue, 02 April 2019, 10:47:37 »
So they release 10 episodes on 3 bluray discs
d1, 4 epi,  8gb/episode
d2, 3 epi, 11gb/episode
d3, 3 epi, 11gb/episode
That IS INSANE !!  Completely illogical.
All 3 discs are dual layer BD50, capacity of 50GB, NONE of the discs are filled. The capacity on the 3 discs only meter out to 39gb / 37gb / 39gb
At the very least, they could do ALL 11gb/ episode.
It's OK to have asymmetry given Constraints,  but there's clearly more room here.
Offline azhdar
  • Praise the AZERTY god
Re: INSANITY
« Reply #1 on: Tue, 02 April 2019, 11:10:54 »
what show ?
Azerty Propagandiste
Offline azhdar
Re: INSANITY
« Reply #3 on: Tue, 02 April 2019, 11:35:24 »
Vikings ?
You bought a physical bluray ?
Re: INSANITY
« Reply #4 on: Tue, 02 April 2019, 12:14:44 »
Vikings ?
Physical bluray ?
Even worse,  was the Avatar bluray.
video file comes out to 38gb for a 3hr movie.
It's also Full 16:9,  which means,  it's gotta spread those bits across 2mpixel  vs  2.35:1 movies @ 1.6mpixel
Even then, 2hr 1.6mpixel movies are usually 38gb
The movie should go the distance and hit 45gb , why not ?
They delivered it in a 3 disc set with special features on 2nd/3rd disc.
Offline azhdar
Re: INSANITY
« Reply #5 on: Tue, 02 April 2019, 14:30:19 »
Couldn't you like download it on the internet ?
Are you lacking storage space ?
Re: INSANITY
« Reply #6 on: Tue, 02 April 2019, 14:56:23 »
Depending on the movie, you could do both.
