Author Topic: 2 stiff..  (Read 3368 times)
2 stiff..
« on: Thu, 23 May 2019, 18:31:35 »
So, Tp4 were wall mounting.
Done the calculations, added half inch (assuming) there'd be a slight sag.
Drilled some holes, Impact driver, zip zip.. all done.
There's absolutely no sag,  which means, This tv is now mounted 0.5 inches TOO HIGH.
Ugh.... Want to killz myself...
No, can't adjust, used an old monitor mount, didn't want to spend zennies for a new adjustable mount.. weight capacity is fine, it's low torque.
  • Live long and prosper
Re: 2 stiff..
« Reply #1 on: Thu, 23 May 2019, 18:34:03 »
tp thread is tp thread
Re: 2 stiff..
« Reply #2 on: Thu, 23 May 2019, 20:17:11 »
tp's be like
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: 2 stiff..
« Reply #3 on: Thu, 23 May 2019, 20:24:46 »
Offline JP
Re: 2 stiff..
« Reply #4 on: Thu, 23 May 2019, 20:45:19 »
About Me | The Collection
Offline invariance
  • ...here with all the other boson's
Re: 2 stiff..
« Reply #5 on: Fri, 24 May 2019, 17:27:17 »
Oh no!
You will have to either:
a) raise your lounge by .5”,
b) incline your head by .003 degrees, or
c) tear it off the wall in a fit of rage and vow to never do anything maths related again.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Re: 2 stiff..
« Reply #6 on: Fri, 24 May 2019, 18:09:09 »
Oh no!
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: 2 stiff..
« Reply #7 on: Sat, 25 May 2019, 15:03:33 »
I don't like when people put the tv very high to the point where you have to stretch your neck for viewing. Afterwards, it hurts and my necks like : ow!
Just my thoughts
