Author Topic: Carbon Fiber Plate vs others  (Read 3322 times)
Offline TeacherGeek
« on: Sun, 26 May 2019, 19:24:38 »
So I've watched some youtube vids with sounds etc, but they never do a fair comparison with another plate with the same case/switches.
I was wondering if you guys had any info on carbon fiber plates, do you recommend it and why would you get it over others? Is it better for a particular switch type?
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
Re: Carbon Fiber Plate vs others
« Reply #1 on: Sun, 26 May 2019, 19:48:20 »
From what I remember, CF plates are very pingy.
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
« Reply #2 on: Sun, 26 May 2019, 21:47:27 »
Keyboards are very low tech by nature.
So all of the possible combinations are primarily Vanity Driven.
Because there is no performance metric , there is no good/ bad comparison.
As to the specific question of CF plate,  it's nothing we can tell you about, you have to try it, you either like it, or you do not for reasons only YOU can or can not explain.
Offline TeacherGeek
« Reply #3 on: Mon, 27 May 2019, 06:13:00 »
Mate, I understand that. But I asked for your opinion about the plate, if you have one, please give it. Thanks!
