Author Topic: 8 Monitors @ 2x MSI 980 Graphics Card  (Read 13705 times)
Offline Naweo
« on: Fri, 26 July 2019, 06:25:22 »
Basic yes/no question I unfortunately had a lazy and hard time finding on google:
Is it possible for me to use 8 monitors on 2x MSI 980 graphics cards, NOT using sli, but the multiple monitor option?
Second question: What would you deem a BenQ G24020HD monitor is worth nowadays?
Thank you!
« Last Edit: Fri, 26 July 2019, 06:36:43 by Naweo »
Re: 8 Monitors @ 2x MSI 980 Graphics Card
« Reply #1 on: Fri, 26 July 2019, 09:26:50 »
You wouldn't do it this way, because it's 24 inch and 1920
They sell a 50 inch for $200-400 nowadays , 4K , IPS or VA.
Each one is almost exaclty 4x 24 inchers put together.
With just 2 of those you'd get the same as 8x 24" and you wouldn't have to align them.
If you're going to sit upclose < 5 feet,  you'll need IPS from LG, watchout for RGBW models which is fake4K.
If you're over 5 feet,  you can get VA from samsung or the TCL 43' models , the 50' TCL and above use spatial dithering, so that may cause problems for certain PC tasks.
Offline Naweo
« Reply #2 on: Fri, 26 July 2019, 09:44:16 »
Like the Dell monitor here?
P4317Q
https://images.techhive.com/images/article/2016/05/dell-43-inch-4k-monitor-100662731-orig.jpg
And you are able to set these up without having to use more than 1 PC?
« Reply #3 on: Fri, 26 July 2019, 09:46:57 »
The dell is a good panel, but you don't have to pay that much if you get a tv instead.
They work on single hdmi or dispport connection.
For TV you'll want to use HDMI instead of a disp-converter, because dispconverter probably won't give you the right gamma curve.
Offline Naweo
« Reply #4 on: Fri, 26 July 2019, 09:53:04 »
Alright thank you.
Actually my cousin already has the dell monitor, I guess I can try and see if I can turn it into 4 displays from a single connection. Would I need anything other than the monitor? (More graphics cards, splitter hardware, etc.)
« Reply #5 on: Fri, 26 July 2019, 10:02:04 »
Alright thank you.
That dell might have an internal option to use 4 connections. I'm not sure. but some business monitors have pip features.
