Author Topic: Cut cherry stab holes into costar holes on filco plate  (Read 12549 times)
Offline kiriiya
« on: Fri, 26 July 2019, 18:56:36 »
Has anyone tried using a dremel to cut cherry stab holes on a filco plate? Anyone have a better idea? I'm really contemplating this...
Offline HPE1000
  • Keycap Paparazzo
Re: Cut cherry stab holes into costar holes on filco plate
« Reply #1 on: Fri, 26 July 2019, 19:23:12 »
It is possible, but I think it would be a lot of work to get it right. What I did was I bought an old ducky shine 2 or 3 plate (cant remember rn) since those have cherry stabs and then I swapped in the filco pcb.
« Reply #2 on: Fri, 26 July 2019, 20:17:54 »
It is, but you might as well use a custom plate.
It's not good to have metal shavings spewing all over a keyboard.
Offline kiriiya
« Reply #3 on: Tue, 22 October 2019, 16:56:01 »
I couldn't find any custom plates compatible with my new case but I did buy a DS3 and it worked! Thanks for the help.
