Author Topic: This is awful..  (Read 3006 times)
This is awful..
« on: Sat, 12 October 2019, 19:29:16 »
My laptop SSD heatspreader doesn't seat flat on the controller chip, so it's NOT TOUCHING all the way..  It's stupid, cuz the  only 2 screws are on diagonal corners of the heat spreaders,  which leads to this outcome.
Fire this engineer.
Re: This is awful..
« Reply #1 on: Sun, 13 October 2019, 12:06:31 »
Sounds like you need some Arctic Alumina, as long as you never want to take it off that is :))
Offline JP
Re: This is awful..
« Reply #2 on: Sun, 13 October 2019, 12:48:45 »
About Me | The Collection
Re: This is awful..
« Reply #3 on: Mon, 14 October 2019, 05:53:46 »
I used AA to add the backside cooler from a Thermaltake IFX-14 to the backplate of my s115x (yes, I'm using the front part too) not sure it does much in the way of cooling mounted like this but looks good.  Even with 4" of heatpipe to use as leverage it's not coming off!
You might be right though, depends if the heatsink is bent/uneven or it's just a badly designed mounting system...
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: This is awful..
« Reply #4 on: Mon, 14 October 2019, 16:54:05 »
Fire this engineer.
Welp, your laptop is overheating.
Just my thoughts
