Author Topic: Cold = Brighter.  (Read 3135 times)
Cold = Brighter.
« on: Tue, 12 November 2019, 19:59:05 »
So, the way LEDs work, The colder they're running, the brighter they are.
TV's running way out of spec.   Calibrated color temp 6534k,  measured today 6683k.
It's running ~ 2% brighter which is what's accounting for the Blue drift.  ~ 10 Degrees difference.
Time to run Winter calibrations..
Offline invariance
  • ...here with all the other boson's
Re: Cold = Brighter.
« Reply #1 on: Tue, 12 November 2019, 20:07:17 »
Ergo, run air conditioning 24/7 @ 20C (68F) for no colour drift  :thumb:
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
« Reply #2 on: Tue, 12 November 2019, 20:12:02 »
Not after buying all these monitors and laptops .. It's all Top ramen and no heat till spring. Huddles next to server 4 heat.  Knowing the EM-wavez prolly giving Epic cancer.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #3 on: Wed, 13 November 2019, 12:07:30 »
Is that why my eyes are irritated now?
Dark theme is just too dark.
Just my thoughts
Offline JP
« Reply #4 on: Wed, 13 November 2019, 15:16:08 »
Wait, so now you're going to need real-time dynamic calibrations based on temperature?  :eek: This or check the calibration for a range of temperatures, do some fancy interpolation, and implement it into your own custom controller for your display which of course would need to have some temperature probes or sensors.
[Edit] Or build an insulated and temperature and humidity controlled room to preserve calibrations.
« Last Edit: Wed, 13 November 2019, 15:24:39 by JP »
About Me | The Collection
« Reply #5 on: Wed, 13 November 2019, 15:31:37 »
Samsung TVs already have something like this, It varies drive current and Rgb balance to target white point as the temperature moves up and down.
It's not accurate to do dynamic though, ideally, you want active cooling + stable room temperature.
« Reply #6 on: Wed, 13 November 2019, 15:41:50 »
Dark themes always screw up my eyes leaving an after-shadow filter on everything I look at for a few mins after. Like when you look at something super bright and everything seems darker for a little while. Normal white themes don't cause this, and constantly blowing out my cones looking at a monitor probably isn't healthy.
Offline invariance
« Reply #7 on: Wed, 13 November 2019, 20:41:10 »
Wait, so now you're going to need real-time dynamic calibrations based on temperature?  :o This or check the calibration for a range of temperatures, do some fancy interpolation, and implement it into your own custom controller for your display which of course would need to have some temperature probes or sensors.
Now we’re onto something, modding tv’s with a phase change cooler.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
« Reply #8 on: Wed, 13 November 2019, 22:45:45 »
Mmm... at max at sub-zero, I think it's ~ 50% brighter. you'd spend more power phase cooling than if you just put in more leds, at lower drive/heat
Going even further, if cost was no concern, Laser would be even better and have much higher light purity.
