Author Topic: KVM Switches are so Expensive  (Read 6361 times)
« on: Tue, 26 November 2019, 11:05:23 »
You might as well Buy m0ar monitors.
Offline _rubik
Re: KVM Switches are so Expensive
« Reply #1 on: Tue, 26 November 2019, 11:07:28 »
It all depends on which KVMs you're after. Older VGA/USB2 models are pretty cheap these days. Multi-input, multi-output with all the modern touches (thunderbolt 3, hdmi, etc etc) will run you a pretty penny.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #2 on: Tue, 26 November 2019, 11:14:40 »
What are KVN switches
Just my thoughts
« Reply #3 on: Tue, 26 November 2019, 13:45:29 »
Keyboard, Video and Mouse - the switch lets you press a hotkey and swap between two computers so you don't have to move.
« Reply #4 on: Tue, 26 November 2019, 15:07:40 »
The Cheapest KVM switch with HDMI is ~ $200
one can buy 2 monitors , 2 mouse + 2 keyboards for that much.
Offline _rubik
« Reply #5 on: Tue, 26 November 2019, 15:11:57 »
But are those 2 monitors,  2 mice, and 2 keyboards all peripherals you'd want? Maybe not.
« Reply #6 on: Tue, 26 November 2019, 17:18:40 »
It's that,  or take it up the butt w/ kvm prices,  out of pride,  it's not something a man should do.
« Reply #7 on: Tue, 26 November 2019, 17:24:51 »
Is there no decent remote desktop software that could do the same job?
Offline _rubik
« Reply #8 on: Tue, 26 November 2019, 19:04:12 »
With remote desktop software you're introducing a lot network lag. It's often fine when in a text based environment, but generally annoying on anything graphical/higher resolution. That and you're relying on a software based solution instead of wire speed.
KVMs are the optimal solution; that said, a lot of datacenters employ IP KVMs (not really for home use, though).
Offline Sintpinty
    • My Roblox Profile
« Reply #9 on: Tue, 26 November 2019, 20:44:12 »
ok
Just my thoughts
« Reply #10 on: Tue, 26 November 2019, 21:52:49 »
Just steal a coworkers station, who needs a switch?
« Reply #11 on: Wed, 27 November 2019, 04:15:51 »
They worked 15 years ago on 100mbit LAN...  Sure there was input lag and the display was choppy when a chunk refreshed, but in this age of streaming games to the internet I expected big improvements.  Obviously someone has to bother to code it though so if you say it's still crap I wont argue :)
Next idea - multi input monitor (aren't they all?) and separate USB switch.  Yes you hve press two buttons to switch but still much easier than moving.
Offline yui
« Reply #12 on: Wed, 27 November 2019, 04:52:49 »
well given your taste in color rendition and i guess since you are here keyboards i would be impressed if you could find either for under 200$, and then a kvm takes less desk space.
There was a time when level1tech's Wendel made a very high end custom DP kvm that would let you use hdr trough, it would be perfect for you.
Offline Coreda
« Reply #13 on: Wed, 27 November 2019, 04:58:24 »
This one?
Offline _rubik
« Reply #14 on: Wed, 27 November 2019, 12:26:27 »
This one?
I forgot how much of a chonker that thing was! I also can't believe they're still selling/stocking those suckers. I guess there's enough demand. I would love to see an updated thunderbolt3 model.
Offline yui
« Reply #15 on: Wed, 27 November 2019, 15:32:43 »
This one?
yeah this one, i did not knew either that they still made it, it was announced as a limited batch thing
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
« Reply #16 on: Wed, 27 November 2019, 17:11:24 »
I do a quick search on google immediatly :cool:
