Author Topic: Fixn dell's st00pid ssd heatspreader.  (Read 2519 times)
« on: Sun, 29 December 2019, 12:09:04 »
232506-0
One can see why this mount is terribly designed, the mounting positions pitch the NON-screw tab side upwards causing non-contact. (the corner where the green-Nub is now)
The Zip ties bring the corner back down.
Little packet says zipties rated up to 85 C, should be gud'
SSD only gets to ~70 C tops in laptop wurkloads.
Another option would be to spend $10 on another heatspreader and Solder down the rear mounting bracket, The bracket below the ssd is loose and mobile, it needs to be soldered if using a heatsink other than the stock heatspreader
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: Fixn dell's st00pid ssd heatspreader.
« Reply #1 on: Sun, 29 December 2019, 15:55:54 »
I think I have the same laptop as you and it is a literal heater with temperatures beyond room temp in Celsius
Just my thoughts
« Reply #2 on: Sun, 29 December 2019, 17:05:49 »
Yea, that's normal, processors have transistors, which dissipate heat like resistors,   Resistors is like a brakes of a car, except for electricity, and if you put current through it,  the brakes get hot.
