Author Topic: Gemini Man (2019)  (Read 4926 times)
Gemini Man (2019)
« on: Sun, 05 January 2020, 13:43:44 »
Just watched the 60fps 4K home version.
High Framerate is clearly still experimental at this point, the technical language used for 24fps does not translate.
Also hardware requirements. 1060 and 1660ti can not do MADVR's HDR dynamic tone mapping @ 60fps  Prolly need at least 2080ti, Had to resort to using the Tv's own crappy HDR tonemapping for playback..
Anyone else see this film in High frame rate ? Thoughts ?
233090-0
Offline yuppie
Re: Gemini Man (2019)
« Reply #1 on: Sun, 05 January 2020, 13:56:06 »
I thought it looked good from the trailer ... Turned it on and started skipping around because the dialogue, story and acting was so bad.
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
« Reply #2 on: Sun, 05 January 2020, 14:23:01 »
Was the acting really so bad, or was it the 60fps making it look fake ?
Even for the mouth movements, because now we can see it so clearly, the dub-over is often visible .
And I'm not sure about this one, but because of the HFR, it gives you a very clear perception of Distance to character, so now it's very obvious that the sound isn't coming from where you Expect it to come from.  Perhaps that Dolby Atmos can address this in the future, but to place sound so precisely, it'd have to have some sort of object based in-home calibration.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #3 on: Sun, 05 January 2020, 17:45:20 »
ended up being terrible
Just my thoughts
Offline phinix
« Reply #5 on: Mon, 06 January 2020, 03:19:52 »
I approached this movie with a light head, watched it and I think it was ok. Not a great movie, but ok - a simple action movie, nothing fancy, but I liked it as a relax time entertainment.
Offline dingusxmcgee
« Reply #6 on: Mon, 06 January 2020, 05:18:57 »
Same here. Wasn’t amazing, but I wasn’t expecting it to be. I like watching Will Smith and it entertained me for $6 in comfy seats so, checks all my boxes.
« Reply #7 on: Mon, 06 January 2020, 08:16:14 »
Thoughts on the High Frame Rate
Offline phinix
« Reply #8 on: Mon, 06 January 2020, 09:40:41 »
I don't even know if it was high frame rate, need to check at home and let you know:)
« Reply #9 on: Mon, 06 January 2020, 09:51:26 »
The 4K bluray version is released in 60fps.
The 1080p bluray version is not 60fps
The Streamed version , don't know.
« Reply #10 on: Mon, 06 January 2020, 10:01:13 »
Saw it in theaters so not sure, but nothing felt off from visual or audio perspective.
« Reply #11 on: Mon, 06 January 2020, 10:29:18 »
Pretty sure it's at least 60fps in theaters,  most newer digi projectors do 60hz.
Offline phinix
« Reply #12 on: Thu, 09 January 2020, 14:53:07 »
I had 1080p - 24fps:(
« Reply #13 on: Thu, 09 January 2020, 15:41:16 »
only 4K version released in 60fps. look for 4K versions. not sure about web 4k versions but you'd be able to tell the difference right away, there's no mistaking 60fps for 24
Offline Coreda
« Reply #14 on: Thu, 09 January 2020, 16:09:58 »
Was projected in selected cinemas at 120fps  :eek:
Will say that young Smith looks more like his son than his actual younger self.
« Reply #15 on: Thu, 09 January 2020, 16:44:54 »
Yea even dolby cinema can only do 2k 120fps,
Very few theaters can do the 4K 120.
