Author Topic: Help Me Spend $500-$700 - New Build Help!  (Read 2146 times)
Offline MavenAZ
« on: Wed, 15 January 2020, 17:18:08 »
 Hello,
I am looking to build a new Keyboard. (75%) - Similar Layout to the Drop CTRL or Razer TE
The CTRL looks good, but I think I could do better and have something as or more flexible for the money. - I do like the hot-swap feature.
Upon scouring the net, I have found the Tofu to be a popular option in the sub $300’s
Would like to get a case a little more substantial. (Similar to others out there like the Matrix OG)
However, it seems like custom cases are not easy to find unless I’m looking in the wrong place.
Thinking of using Holy Pandas or Gateron Ink Blacks
Is there a board out there that allows for both wire and and wireless?
This will be a gift to me now that I'm getting a little older. Looking forward to getting all the pieces together and enjoying it for a long time to come.
Thanks for your input and time in advance!
« Last Edit: Wed, 15 January 2020, 17:23:38 by MavenAZ »
Re: Help Me Spend $500-$700 - New Build Help!
« Reply #1 on: Wed, 15 January 2020, 18:27:23 »
:Cautionary:
We @ GH have all taken the plunge
But,  Keyboards do not give FPS. One might kick oneself in the face, if one forgoes Gtx 2080 for Aluminum keyboard.
That said, Tp4 recommends ne Split keyboard, tentable to 55 degrees+
Offline MavenAZ
« Reply #2 on: Wed, 15 January 2020, 23:09:21 »
:Cautionary:
Split layouts are a no-go due to elbow and shoulder issues.
I’m covered in the GPU department!  :cool:
Offline lolafineday
« Reply #3 on: Thu, 16 January 2020, 00:52:14 »
Look around in the interest checks section for the keyboard interest checks, or search around and ask on keyboard discord for recommendations. This is my best recommendation. Mech discord servers tend to have a lot of knowledge.
Sent from my SM-G975F using Tapatalk
Offline treeleaf64
    • treeleaf64
« Reply #4 on: Thu, 16 January 2020, 10:36:15 »
I'm not really into customs, let alone expensive ones. Try to get some brown Alps and make a build with those, I doubt you'll regret it! :)
Everyone must pay the cat tax
« Reply #5 on: Thu, 16 January 2020, 11:28:02 »
Cough.. Dear MavenAZ ...  Have you hurd the Gud'Wurd of  THREADRIPPA...
233791-0
Offline treeleaf64
    • treeleaf64
« Reply #6 on: Thu, 16 January 2020, 11:36:20 »
In all seriousness, isn't there a new Threadripper that came out/ is about to come out soon.
