Author Topic: It gets STuCK..  (Read 3676 times)
It gets STuCK..
« on: Sun, 09 February 2020, 13:36:29 »
Put this Expresscard into my beloved X220, it gets stuck. I don't understand. the spring wont' eject the card.  Is it non standard spec?
2 Get it out,  need to clamp on with tweezers. ??
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: It gets STuCK..
« Reply #1 on: Sun, 09 February 2020, 20:24:11 »
Speaking of stuck, my mouse cables always get stuck in my laptop
Just my thoughts
Offline Coreda
Re: It gets STuCK..
« Reply #2 on: Sun, 09 February 2020, 20:46:41 »
What if your mouse was stuck in your laptop.
Lack of storage is the problem with modern laptops. Not enough room inside. Bring back the chonky bois of yore, with drawers.
« Last Edit: Sun, 09 February 2020, 20:48:34 by Coreda »
Offline yui
Re: It gets STuCK..
« Reply #3 on: Mon, 10 February 2020, 01:10:40 »
Put in this Expresscard into my beloved X220, it gets stuck. I don't understand. the spring wont' eject the card.  Is it non standard spec?
the spring should eject the card, at least it is how it works in my hp, when you put it in you felt excessive friction (should slide in easily)? if no it might be that the ejection mechanism on your trusty x220 is dead, and anyway if it does not come out you have 2 choices, either you take a screwdriver and start to tear into the pc (time consuming) or take pliers to the card (risk of damage to the card/express connector).
Re: It gets STuCK..
« Reply #4 on: Mon, 10 February 2020, 01:30:17 »
I think it's just too thick. I can feel the spring tension when I push/pull on the card, so the top and bottom is just too tight.   Sigh...
AND my earbuds just broke.. Wonderful.. sigh...................
Offline SBJ
  • Tactile pls
Re: It gets STuCK..
« Reply #5 on: Mon, 10 February 2020, 01:40:40 »
That's an excuse to get even better ones.
Re: It gets STuCK..
« Reply #6 on: Mon, 10 February 2020, 02:17:11 »
Sigh.. I feel like they don't last long. Maybe I'll get metal ones.
The cord seems the be the biggest weakness.
I've always stuck with sennheisers, they last ~2-3 years a pair.
Guess I should be getting one with metal braces.
Offline yui
Re: It gets STuCK..
« Reply #7 on: Mon, 10 February 2020, 03:46:46 »
i had some akg k141 mk2 that had a detachable cable. lasted about 6years, they included 2 cable in the box and had to buy a new one, in the end the connector on the headphone side broke, and akg are not making parts anymore, and if you are more of a headbuds person venture electronics makes some very nice stuff, and cheap (their monks are about 5 usd and are nice, and they have in ear monitors with replaceable cable, much more expensive though)
Offline Sintpinty
    • My Roblox Profile
Re: It gets STuCK..
« Reply #8 on: Mon, 10 February 2020, 05:28:23 »
Mines is big
I can hardly fit it on my desk
Just my thoughts
