Author Topic: Color Accuracy vs Resolution  (Read 2153 times)
« on: Sun, 26 July 2020, 21:45:11 »
Dis' netbook is so slow,   It can either run
720p w/ color correction enabled,
OR 1080p w/out color correction.
Which would you guys choose ??
Offline Olumin
  • "Guy walks into a doctor's office..."
Re: Color Accuracy vs Resolution
« Reply #1 on: Sun, 26 July 2020, 21:53:37 »
If it’s that slow you probably won’t be doing any video/image editing or anything that requires high color accuracy to beginn with..
So.. 1080p?
« Reply #2 on: Sun, 26 July 2020, 21:55:08 »
1080p this isn't even a question
« Reply #3 on: Sun, 26 July 2020, 21:55:10 »
If the native pixel size of the panel is 1080 on the vertical, then because 720 is ⅔ of 1080, 720 would not scale evenly and look crap. Therefore 1080.
If I instead had to choose between two netbooks, then 1) whichever has PPI in the sweet-spot of 100-120 (or >300),  2) IPS or VA over TN.
« Last Edit: Sun, 26 July 2020, 22:04:50 by Findecanor »
