Author Topic: Which keyboards give you ASMR?  (Read 7591 times)
Offline grapefruit
« on: Thu, 20 August 2020, 14:06:22 »
ASMR ("autonomous sensory meridian response") is a kind of delicious, pleasurable bodily response to certain kinds of sounds... like certain kinds of whispers, someone running through finger across a comb, etc.
You can see a video example of it here:
Which keyboards give you the greatest ASMR?
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
Re: Which keyboards give you ASMR?
« Reply #1 on: Thu, 20 August 2020, 14:30:53 »
IBM Model M, especially my second one after a bolt mod. It seems to have dampened some of the higher pitch components after I tightened everything up.
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
Offline ddrfraser1
  • RIP Neil
« Reply #2 on: Thu, 20 August 2020, 15:31:31 »
This one I built... surprisingly  :cool:
https://geekhack.org/index.php?topic=105767.0
Offline Error213
« Reply #3 on: Thu, 20 August 2020, 15:32:46 »
I think it’s more of a matter of the switch. Like lubed gat inks and yellows sound amazing on basically anything
Offline rxc92
« Reply #4 on: Thu, 20 August 2020, 15:53:13 »
Pretty much any switch (besides clicky) can sound really nice, but I am usually wearing headphones and typing quickly enough that it’s hard to appreciate the sound of my keyboard.
Offline ddrfraser1
  • RIP Neil
« Reply #5 on: Thu, 20 August 2020, 17:35:56 »
Untrue. You just haven't heard it yet.
Offline powwu
    • Discord
« Reply #6 on: Thu, 27 August 2020, 15:50:50 »
I watch ASMR, but I don't really experience it. I just watch ASMR to relax. So, to say that I just like the sound of a board, I like the sound of a lubed linear/tactile on a polycarbonate plate. There is something about it that nothing else can compare to.
Offline ollir_
« Reply #7 on: Fri, 28 August 2020, 06:26:56 »
I've experienced ASMRs in the past before it became a "thing". I don't get the sensations from any youtube videos or from keyboards for that matter. Have only experienced it very very lightly from watching an ASMR video, but not enough to really make me watch them more.
« Last Edit: Sun, 30 August 2020, 12:12:30 by ollir_ »
Offline jamster
« Reply #8 on: Fri, 28 August 2020, 08:05:02 »
Not from keyboards. These things strike me as some of the least likely objects to generate it. Wrong frequencies, (both sonic and timing). It's like saying you can get ASMR from tapping your fingers on a table.
Offline BioOrpheus
« Reply #9 on: Fri, 28 August 2020, 19:28:51 »
This one
Offline Learis
« Reply #10 on: Fri, 28 August 2020, 23:39:13 »
Here's one of my favorites. The singa
Mend and Defend
Offline Polymer
« Reply #11 on: Sat, 29 August 2020, 14:10:30 »
HHKBP2
Thocky, ploppy, rain drops....sometimes I just tap on it unplugged......
« Reply #12 on: Sat, 29 August 2020, 17:04:30 »
most switches are too loud for that unless they're really far away.
Offline funkmon
« Reply #13 on: Mon, 31 August 2020, 02:11:53 »
Is it weird that these ASMR sounds and videos just sound icky to me?
Offline jamster
« Reply #14 on: Mon, 31 August 2020, 02:44:06 »
That one in the opening post was certainly bloody weird. And yeah, sounded icky with the strange glottal noises.
That one was just creepy for multiple reasons.
Edit: Is this a "what keyboard do you like thread" or do people seriously get this from keyboards?
Autonomous sensory meridian response (ASMR), sometimes auto sensory meridian response, is a tingling sensation that typically begins on the scalp and moves down the back of the neck and upper spine. A pleasant form of paresthesia, it has been compared with auditory-tactile synesthesia and may overlap with frisson.
« Last Edit: Mon, 31 August 2020, 07:00:40 by jamster »
Offline killyou
« Reply #15 on: Mon, 31 August 2020, 06:42:12 »
In my opinion it's not the keyboard itself but switches, keycap profile and keyboard chassis to some extent. I like switches that are tactile, crisp in both sound and tactile feedback, and not overly hard to bottom out. From sound perspective the most pleasurable combo for me was SA keycaps + Kailh BOX Jade switches which produce deep and crisp click sound. I also tried Cherry and OEM profiles and I absolutely hate Cherry profile both in sound profile and just how short they are. Having said that I think OEM (for instance the one found on Pok3r keyboards) suits me perfectly and even after buying some GMK and SA keysets I keep typing on original Pok3r keycaps. I just love the material and profile. Coming back to switches BOX Jades are not the best experience because they work like a binary switch, it's either pressed or depressed. Due to the sharp force curve and light spring it's hard to have any travel, it just bottoms out immediately after overcoming the bump. BOX Navy switches on the other hand are too heavy but typing experience is nicer. I found a good middleground in Kailh BOX Pinks with Kailh BOX White/Jade springs. They are easy enough to press, they do not tire my hands after typing all day and they still produce nice sharp click. I'm using them with OEM keycaps and that's the best experience I ever had and I cannot match it ever since I started using this combo.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #16 on: Mon, 31 August 2020, 08:56:37 »
Box whites
Just my thoughts
