Author Topic: WT60-D Weirdflex PCB  (Read 6130 times)
Offline diazel
« on: Thu, 17 September 2020, 11:08:02 »
So NK has this weirdflex pcb on their site where it's got two long slots cut into the PCB on either side of the alpha block. Apparently has so much flex in it when built sans plate or half plate that it's advisable to add foam to control the amount of flex.
I am so intrigued but I have enough project PCBs laying around me right now so I'm not picking it up but I'm wondering if anyone here has used one and what their thoughts were. I can't seem to find a review of it on youtube which kind of makes me want to buy it, build it, and send it to Thomas/Chyrosan88 to have him do a review.
So, anyone use it? Would you recommend?
Here's the link for the PCB: https://novelkeys.xyz/collections/frontpage/products/wt60-d-weirdflex-pcb
Offline treeleaf64
    • treeleaf64
Re: WT60-D Weirdflex PCB
« Reply #1 on: Thu, 17 September 2020, 22:18:27 »
No please don't send it to Chyros    to review
Ok basically it will be very flexible pcb. .. . I tried thin pcb vs thick pcb, it makes different noises and different feel as well. 1.2 mm is more flexible vs 1.6mm
Everyone must pay the cat tax
Offline diazel
« Reply #2 on: Thu, 17 September 2020, 22:21:20 »
You didn't say whether you liked it or whether you'd recommend. Only told me it was more flexible because it was thinner lol
Sent from my ONEPLUS A6013 using Tapatalk
Offline treeleaf64
    • treeleaf64
« Reply #3 on: Thu, 17 September 2020, 22:23:37 »
Yeah I liked it, only thing is it's kinda expensive, if you can I would make your own plainflex from jlcpcb
Sure I'd recommend if it's avail.  but again everything in this hobby is preference , you might like stiff pcb or you might like  thinner ~~
tree leaves
Offline diazel
« Reply #4 on: Mon, 21 September 2020, 14:59:08 »
@treeleaf, have you done that before? I would absolutely love to do this but admittedly would have no idea where to start. I'm going to start doing some research but if you had some reference material, it would be very appreciated!
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #5 on: Mon, 21 September 2020, 15:12:55 »
If flex is what you're after the weird flex PCBs would be the way to go IME. I am typing on one right now that is setup in a half plate build in my Sirius. It flexs enough to hit off the bottom of the case if pressed a little harder than typing pressure. As far as recommending it goes, I definitely would as long as you are using it plateless or half plate. You'd probably get some extra flex on a full plate if the material is something like polycarb or POM, but I wouldn't pay the extra price for one of these to use in a full plate build TBH.
Offline treeleaf64
    • treeleaf64
« Reply #6 on: Mon, 21 September 2020, 21:54:45 »
My friend Vidas did it, you can see his post on the Geekhack here
https://geekhack.org/index.php?topic=108283.0
« Reply #7 on: Mon, 21 September 2020, 22:12:32 »
Dis' how u break solder joints and crack traces..
Offline diazel
« Reply #8 on: Tue, 22 September 2020, 06:55:28 »
Where's your sense of adventure TP4? ;)
ps. I'm a light touch typer. If I was heavy handed, I wouldn't think of it but the idea is fun for a side project.
Offline NoteMakoti
  • for sale, baby shoes, never worn
« Reply #9 on: Sat, 27 February 2021, 18:24:45 »
I just ordered this, wish me luck. Gonna make a plateless 60%.
Offline hanya
« Reply #10 on: Sat, 27 February 2021, 19:43:37 »
FILCO reported the cause of solder crack is bent of their PCB. And they have updated to use harder PCB to avoid such problem.
DIY keyboard choose wrong direction about flex PCB.
PFU HHKB JP, Sanwa MA-TB38 trackball
« Reply #11 on: Sat, 27 February 2021, 21:48:53 »
It's really hard to make a flexible PCB that you solder all over.  They usually divide up the pcb into sections where the part that needs to bend has nothing soldered so that joints won't crack.
