Author Topic: fixed dis'Lamp  (Read 2746 times)
fixed dis'Lamp
« on: Sun, 15 November 2020, 22:21:34 »
pr00f of Tp's p00rditude.
255912-0
Re: fixed dis'Lamp
« Reply #1 on: Mon, 16 November 2020, 00:13:17 »
I see no sign of burrs on your cuts and that's clearly not scavenged wood - looks like an environmentally motivated fix not poortitude.  A bit of paint and you'd never know :thumb:
Offline yui
Re: fixed dis'Lamp
« Reply #2 on: Mon, 16 November 2020, 06:34:21 »
saving the planet, one lamp at a time :)
Re: fixed dis'Lamp
« Reply #3 on: Mon, 16 November 2020, 08:47:59 »
Also, +10 firehazard.
Re: fixed dis'Lamp
« Reply #4 on: Mon, 16 November 2020, 11:50:51 »
It uses an actual light bulb?!
Re: fixed dis'Lamp
« Reply #5 on: Mon, 16 November 2020, 12:30:07 »
switched to these $1 led bulb, guarantees cheapie drivers.
Re: fixed dis'Lamp
« Reply #6 on: Mon, 16 November 2020, 12:40:03 »
Are you expecting the cheapie driver to short and produce enough heat to make the metal shade glow without tripping the fuse?  That would be very unlucky...
Re: fixed dis'Lamp
« Reply #7 on: Mon, 16 November 2020, 13:22:02 »
with luck, it will spark some where, catch on fire, Tp4 sues successfully, move to canada ?
Offline yui
Re: fixed dis'Lamp
« Reply #8 on: Tue, 17 November 2020, 02:17:37 »
from my experience with cheap LED driver they undersized the transistor that gives up in a few months or the bootstrap capacitor fails from the heat of the transistor in both cases your lamp will not fail catastrophically, it will either not turn on or blink...
bottom line buy a few spares for when it fails.
