Author Topic: Topre? Part 2.  (Read 2856 times)
Offline Error213
Topre? Part 2.
« on: Sun, 29 November 2020, 18:55:51 »
Ok well this is it, at the time of me typing this my first topre? Post got a lot of traction with 75 reply’s and over 4000 views, that’s insane. Now I’m planning on taking the leap of faith and buying a topre keyboard, anything that won’t shatter my bank? (Preferably under 200$)
Offline jamster
Re: Topre? Part 2.
« Reply #1 on: Sun, 29 November 2020, 19:34:32 »
Did this really need a new thread?
Offline Error213
Re: Topre? Part 2.
« Reply #2 on: Sun, 29 November 2020, 21:56:01 »
idk
Re: Topre? Part 2.
« Reply #3 on: Sun, 29 November 2020, 22:01:20 »
This is forum mis-use, poor-conduct, bad-etiquette, but Tp4 wont' stop you.
Offline therealemanuelmartinez
Re: Topre? Part 2.
« Reply #4 on: Sun, 29 November 2020, 22:24:22 »
I'm going to go out on a whim and give a reserved maybe. @Error213 if you're in the market for Topre switches, here's the short answer. Topre Corp. sells RGB keyboards and I only like those because they come with cross stem sliders preinstalled. A pack of cherry compatible sliders are about $20 if shipping is free. Leopolds go for just as much if not more than MSRP Realforce and HHKB. You'll be hard pressed to find what you want under $200 unless you seek out used boards that tend to get snatched up faster than you can ask for them, and if they are aftermarket consider yourself lucky if they are less than $190. Do keep an eye out since a lot of people get in and don't like the switch mechanism. That's the best gateway info you can get out of anybody that will reply here unless they want to sell you their keyboard for your price range.
Offline Error213
Re: Topre? Part 2.
« Reply #5 on: Sun, 29 November 2020, 23:06:40 »
how?
Offline walie
Re: Topre? Part 2.
« Reply #6 on: Mon, 07 December 2020, 12:14:28 »
Holy crap this thread really blew up :D. Thank you all for the responses but I don’t think I will get topre, it’s too pricey for something idk if it will be good.
Your last response in your previous post
Offline Sup
Re: Topre? Part 2.
« Reply #7 on: Mon, 07 December 2020, 12:22:37 »
Reddit mech market get a second hands HHKB Pro 2 or Realforce R1 these go usually go for 150-180 dollars.
current
Coming soon
