Author Topic: 100th post  (Read 4113 times)
Offline aleck
  • im so full of topre yum
100th post
« on: Tue, 19 January 2021, 14:10:58 »
hello hi how are you
HHKB Pro 2 Type-S (2016)
Offline aleck
Re: 100th post
« Reply #1 on: Tue, 19 January 2021, 14:14:43 »
this should do. yea
Re: 100th post
« Reply #2 on: Tue, 19 January 2021, 14:19:42 »
You need to post in one of the other sections for the post count to go up.
Offline aleck
Re: 100th post
« Reply #3 on: Tue, 19 January 2021, 15:04:10 »
why is youre text blue
Re: 100th post
« Reply #4 on: Tue, 19 January 2021, 16:59:31 »
It's Teal
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: 100th post
« Reply #5 on: Tue, 19 January 2021, 18:20:22 »
TP4s signature style
Just my thoughts
Offline aleck
Re: 100th post
« Reply #6 on: Tue, 19 January 2021, 21:13:07 »
It's Teal
blu
Offline dingusxmcgee
Re: 100th post
« Reply #7 on: Wed, 20 January 2021, 00:33:42 »
Offline yui
Re: 100th post
« Reply #8 on: Wed, 20 January 2021, 01:07:57 »
It's Teal
TP is a cousin to the i'm blue aliens :) although he is teal instead of blue
Re: 100th post
« Reply #9 on: Wed, 20 January 2021, 04:05:18 »
It's Teal
blu
It’s Teal
It's possible aleck's monitor requires calibration.
Tp4 recommends i1display studio colorimeter.
Offline Darthbaggins
  • PC Cannibal
Re: 100th post
« Reply #10 on: Wed, 20 January 2021, 07:41:09 »
Looks teal to me on my monitors at work.
Re: 100th post
« Reply #11 on: Wed, 20 January 2021, 08:54:08 »
It's criminal to be stuck with a bad monitors !!
/Calibraatt
  • PC Cannibal
Re: 100th post
« Reply #12 on: Wed, 20 January 2021, 08:55:41 »
The panels I use at work are bad but calibrated as well as they could be.
Offline yui
Re: 100th post
« Reply #13 on: Wed, 20 January 2021, 09:02:26 »
in a lot of color grouping teal is part of the blue group though, so for some teal is just blue, although it is only a guess, trying to make sense of that mystery (tp is the next dress :-))
and at work i have 2 screen that a both real far in calibration, and from one an other, but looks teal on both :) (and no i am not even going to try calibrating a 10 and 13 years old displays)
  • PC Cannibal
Re: 100th post
« Reply #14 on: Wed, 20 January 2021, 09:15:48 »
only tool I had at my disposal was a Spyder Pro 5, want to pick up an i1 now that I know what I know.
Re: 100th post
« Reply #15 on: Wed, 20 January 2021, 10:00:21 »
Tangentially off-topic:
Default Geekhack orange-on-black is hideous and almost makes my eyes bleed.
Whenever it defaults itself I immediately change back to the easy-on-the-eyes "Austere" setting and assumed that a lot other people do that too. That has been my choice since very near the beginning.
- D Trump 2026-10-24
  • PC Cannibal
Re: 100th post
« Reply #16 on: Wed, 20 January 2021, 10:09:54 »
Nope leave it as Orange and Black, the black background is easier on my eyes vs the white.
Re: 100th post
« Reply #17 on: Wed, 20 January 2021, 10:43:27 »
It depends on what you do. spyder 5 works more/less ok on ips/tn panels if you use the bundled software.
It doesn't work with displaycal frontend though as it creates dead zones.
