Author Topic: Humidity (Updat Tsu, Oem vs Aftermarket)  (Read 4055 times)
« on: Sun, 07 February 2021, 09:58:15 »
Results are in,
Aftermarket filter ________ 303ml / hour
OEM filter ______________417ml/ hour
That's +37%
Overall, this humidifier model is slightly more efficient than ultrasonic @ 35watts to do 417ml/hour,
11.91 (ml/h)/watt
but it is (Less) efficient if using the aftermarket-filter.
8.66 (ml/h)/watt
Ultrasonic did 260ml/hour @ 25 watts. 10.4 (ml/h)/ watt
Tp4 only tested the lowest fan speed because the higher speeds are super too loud.
This is the only acceptable loudness @ 44 db.
_______________________________________________________
Already feel dat moisssssssss.
Will be doing oem vs aftermarket filter comparison, stay-tuned.
261809-0
_________________________________________________________
Package is to be delivered 2day,  buhhh the street has disappeared under snow.
What's fedex's policy in these cases do they head out ?
How many inches before the day is canceled ?
Offline Faceman76
Re: The Bad Kinda Snow Day
« Reply #1 on: Sun, 07 February 2021, 10:50:32 »
Amazon?  Good luck.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
« Reply #2 on: Sun, 07 February 2021, 11:30:39 »
Vans are heavy and have good ground clearance so should carry on with a bit of snow.  That you have to ask suggests snow is not a common occurrence though so maybe you're out of luck, if I couldn't make out the pavement from the road I know I wouldn't get anything here.
« Reply #3 on: Sun, 07 February 2021, 11:39:35 »
« Reply #4 on: Sun, 07 February 2021, 12:21:00 »
Delivery status - not attempted -
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #5 on: Sun, 07 February 2021, 17:43:05 »
In canada we have this every day
Just my thoughts
« Reply #6 on: Mon, 08 February 2021, 09:17:47 »
Sigh........ no go today either, they plowed, but it's been scheduled for tuesday.  sigh...........
Tp4 must suffer the lack of proper humidity for 1 more day
Offline yui
« Reply #7 on: Mon, 08 February 2021, 09:40:47 »
put the snow on your heater, and then magic the humidity will go up :)
« Reply #8 on: Mon, 08 February 2021, 10:09:13 »
Hrrrm.. settled snow density is only 1/3 that of water, require a huge tank to evaporate snow.   The energy cost might not be worth it.
« Reply #9 on: Mon, 08 February 2021, 15:34:58 »
It's here, moissssssssss
Tp4 bought also the aftermarket filter,  Will be doing comparison between OEM filter and Aftermarket.
The OEM wick filter is 500g weight, the Aftermarket is 200g,  so yea it is lighter, but we'll see if that makes any huge performance difference.
The top round hole is an intake, it pushes the air against the wick, and moisss out the front slanted slots.
~44 db @ 1 meter.   Acceptable noise lvl, it's a gentle woosh, nothing high pitched.  Overall good design.
Supposedly it can do 2700sqft, but that's bullsh, because the highest fan speed sound lvl goes jet engine. No one would conceivably run that daily.
Fill-up is easier than anticipated, it takes 6 gallons, So just take a plastic organizer tub in the sink and that's ~3 gallons, 1, 2, fill.
261807-0
Re: The Bad Kinda Snow Day (Updat, it's Here)
« Reply #10 on: Mon, 08 February 2021, 15:54:06 »
tp should do a write up on air purifiers, it's a great rabbit hole
Sometimes I'll spend entire evenings comparing air purifier stats for hours like a maniac
« Reply #11 on: Mon, 08 February 2021, 15:59:39 »
Tp4 has been down that hole.
Specifically, air purification is useful for SINGLE enclosed room only.  It's not practical to do large spaces because of leaks.
HVAC also pulls in about 30-45% of outside air, This is a building requirement, there's NOTHING you can do about this.  So you're just burning money trying to do the whole house against its' very design.
If you tried to filter the 45% of incoming outside air the filter cost is ENORMOUS.
Re: Humidity (Updat Tsu, Oem vs Aftermarket)
« Reply #12 on: Sun, 14 February 2021, 14:18:51 »
Results are in,
OEM filter ______________417ml / hour
That's +37%
11.91 (ml/h)/watt
8.66 (ml/h)/watt
OEM, 500g of material
262244-0
Aftermarket, 200g of material
262246-1
Offline yui
« Reply #13 on: Mon, 15 February 2021, 01:58:55 »
although it is impressive that with less than half the material they manage to only drop a quarter of the performances, if it was 300g it may have made the whole system even more efficient.
« Reply #14 on: Thu, 18 February 2021, 19:53:21 »
A few days with this thing. Love it.  With some slight modifications, made air guides from tape, upped the total output to 500ml/hour, +20% .
It was leaking alot of airflow on the two sides and top of the filter holder.
The unit is very open and easy to clean.  The Ultrasonic had so many little crevices and places where the hand can't get into, this one is just 1 big tub.
No white dust everywhere this is hugely beneficial.
