Author Topic: Is it possible to swap a Leopold FC750R PD's pcb with a different one?  (Read 3557 times)
Offline Tismody
I've only been into this hobby for 3 months, and I don't really know that much. And I'm planning to customize a Leopold FC750R PD and swap out the pcb with a different one that supports 5 pin switches and pcb mounted stabilizers. Do I need a specific pcb or will this not work with any other pcbs?
Offline Polymer
Re: Is it possible to swap a Leopold FC750R PD's pcb with a different one?
« Reply #1 on: Sat, 20 February 2021, 17:51:26 »
But what are you left with after that?  The keycaps and case?  The caps are nice but the case is a 15 dollar case...surely you can just get whatever PCB you really want and maybe pay for a bit more of a premium case...
Offline Tismody
« Reply #2 on: Sat, 20 February 2021, 23:05:37 »
Yeah you're right. Do you have any recommendations on what pcb and case I should swap with?
Offline Sup
« Reply #3 on: Sun, 21 February 2021, 07:19:40 »
There is no replacement PCB made for the Leopold.
current
Coming soon
Offline yqqdrasil
« Reply #4 on: Sun, 21 February 2021, 08:56:34 »
I believe there are files available if you want to get your own made.
